If you don't have Jackpoint stands.......
At the risk of incurring some wrath, I have to ask - why not just put down the money for the Jackpoints? They are the best solution on the 991. Its a Hundred Thousand Dollar Car, what's $ 300 worth of hardware to lift it correctly and without damage? Jackpoint will even give you a discount being a Rennlist member though I can't recall how much it is. I was hesitant to order a set as well, I have at least (6) conventional jackstands and (2) floor jacks already....but like you I ran into the same issues. I didn't really want more stands to have to store (and the Jackpoints are not small). However since I bought them, the old jackstands are getting cobwebs on 'em and used only for my pickup truck now. I think they really are the solution to the problem on the 991.
Have some - yours look better...
I spoke to a P-dealer tech where I've taken my car for service & he told me the frame rail which runs front to rear under the car, between the wheels & just inside the the body rocker panels & outside the jacking points, would work too, as long as you stayed as close to the jacking points as possible.
In searching old posts on this forum & others - some have stated not a good plan & have actually bent those rails + some resulting in body damage. Maybe if one took a hockey puck & cut a slot to accept the thin rail would possibly solve this problem - might have to trim/thin it to fit also.
Oh, and might as well state that my other safety back-up are putting the wheels under the car and chocking of course! But this is all mainly for when I know I have to be completely under the car for more than a few minutes.....
Jumping-in late for sure, but just the other day put my car up on 4 stands and do not own the jackstand product. I found that I had no issue whatsoever with lifting from a few inches in front of the rear jack-point with my 2-ton floor jack and a hockey puck. Didn't bend the pinch weld even though I didn't modify the puck either. The puck simply deformed to the shape of the weld. Have been doing this for years without issue. However I wouldn't recommend doing this any longer than you need to get the stand in place under the jack point though, to be on the safe side. But I will add that as a safety, when car is up on 4 stands especially, I always place my floor jacks in the same position, just about a "smidgen" from making contact with the pinch weld, so if for some reason the car moves from the stand I have back-up!
Thank you
You can also use pinch weld jack adapters for VW, Subaru, Mazda, etc. I've been using the yellow VW one on my e30 M3 for years.
http://www.ebay.com/itm/like/3312800...lpid=82&chn=ps
http://www.ebay.com/itm/like/2312991...lpid=82&chn=ps
Are the jack point plates completely stable on the jack throughout the lift? Any tendency to slip/shift? If not, is there a design element that prevents that or is it solely dependent on the functionality of the jack? If the plate shifts during the lift as the jack transitions under the car (floor jacks) the car could fall off the jack. Thanks.
Say's the guy who buys lemon BMW's to get a deal...
https://rennlist.com/forums/991/8479...l#post11867821
EDIT:
If it's not already obvious, PM drcollie for Jackpoint jack stands - he's their unpaid (I think?) sales rep.
EDIT:
EDIT: drcollie decided to send me a nasty PM a few minutes ago..
deleted the content from his post ...but reported to admin none the less.
I don't think there should be any true fighting here. All the OP was looking to get resolved is any alternatives to the Jack Point option. I'm not sure what the issue is with that?
There's guys here that spend 20K on filling up the whole car with leather, but balk at a $600 yearly service visit.
Spend 150K on a car, and try to think of ways to save $300 on getting unapproved tires.
You get the picture.
Whatever the OP's reasoning is, what does it matter? It's good to have multiple ways of getting from point A to B I would think. It benefits everyone sharing ideas.
Only semi related perhaps, but I had my first all four tire change yesterday at the local Discount Tire. Rather than use their drive-on "plate" lifts, four techs each manned a jack at all four jack points and they lifted the car in unison. Car was like that for around 30-45 minutes while they swapped out the tires.
Of course, I don't have four jacks and wouldn't get under the car using that method, just an anecdote.
I certainly understand the OP's position and he is not alone or out of line in my opinion. I receive MANY comments about the price of the jack stands being too high. I understand those comments - they are 10 times what you'd pay for some jack stands. I'll just say this. Starting with $60 worth of raw material - it takes 4-5 guys working at US wages 1 day to make 5 - 6 pairs of basic castings. We had a 6.5% price increase from the manufacturing foundry last October notwithstanding our largest volume ever. There is NO discount for volume. To put it in perspective - I shopped US foundries last year and was quoted as much as $306/pair for raw castings at the loading dock. No quotes came in that would touch the current costs - even with the increase. We are always looking for a less expensive way to make them.
