Replacement tires for 991
Old Nov 13, 2014 | 12:25 PM
stevebmd's Avatar
stevebmd
Default Replacement tires for 991
I need to replace my tires on my 19 inch wheels. Had Goodyear F1 and got good tread life but meh wet weather traction. Tried to replace them but was told by my local dealer the were out of stock and my local and very reputable Radial Tire fitted me with Bridgestone RE070 A/S but in 235/35/19 and 295/30/19 and the look cartoonishly small in the already large wheel wells. The ride is a bit more jarring too.
Ant other recommendations for an A/S perhaps with a different width/Section combination?
Old Nov 13, 2014 | 12:29 PM
StudGarden's Avatar
StudGarden
Lots of people seem to like the Pirelli P Zero or Michelin Pilot for summer and Pirelli Sottozero Series II or Michelin Alpins for winter.
Old Nov 13, 2014 | 12:31 PM
stevebmd's Avatar
stevebmd
...but those seem to be summer not A/S tires, correct?
Old Nov 13, 2014 | 12:36 PM
Vise's Avatar
Vise
Correct, why go with the compromise in all conditions A/S tire vs the right tire for the right season? Porsche recommends the tires mentioned above for summer/winter for a reason.
To each their own but I will always get the correct tire for the time of the year... vs 'no season' tires.
Old Nov 13, 2014 | 12:45 PM
Mondrian's Avatar
Mondrian
This thread might be of help.
https://rennlist.com/forums/997-foru...endations.html
Old Nov 13, 2014 | 11:44 PM
lunarx's Avatar
lunarx
There are some All Seasons in your proper size of;
245-40-19 / 285-35-19
Eagle F1 Asymetric
Conti ExtremeContact DWS
Pilot Sport A/S
Old Nov 14, 2014 | 08:51 AM
WCE's Avatar
WCE
User
Those tires are the wrong size...
Curioius, how many miles did you get out of the GYs?
Old Nov 14, 2014 | 09:16 AM
drcollie's Avatar
drcollie
All Season tires on a Porsche 991 are like taking a shower with your socks on.
Old Nov 14, 2014 | 10:13 AM
Vise's Avatar
Vise
Old Nov 14, 2014 | 11:34 AM
stevebmd's Avatar
stevebmd
WCE, I got 18k til I was through to the inner most threads, interestingly, the remainder of the tire was still not down to the wear bars, It was hard to tell they were so bad off because of where the wear was.
I have a feeling I am going back to the asyms F1
Old Nov 14, 2014 | 02:15 PM
Larry Cable's Avatar
Larry Cable
camber!
Try the Michelin Pilot Super Sports
Old Nov 14, 2014 | 06:28 PM
chuck911's Avatar
chuck911
Such uneven wear as this indicates a poor match between car setup and use. With a lot of camber tires will wear evenly only if used with quite a bit of hard cornering. Hard cornering wears the outside fast which evens out with the camber wearing out the inside fast the rest of the time. If this is your situation then you'd be better off running less camber. Your car will feel the same or better, your tires will last longer, and you won't miss what you're not using.
Old Nov 14, 2014 | 08:20 PM
CSK 911 C4S's Avatar
CSK 911 C4S
I had extremity poor tire performance with the OEM P-Zero's on the C4S.
I bought the car with 2700 miles at 8500 the rears were worn evenly down to the wear indicators and the fronts were cupped to where you could feel vibration in the wheel and the inner edge was worn out.
After installation of the Michelin PS+ and an alignment, which uncovered the car had a good bit of negative camber, the new tires are wearing extremely well. I have 21000 on the car and the tires still have a bunch of tread left and that's including one track day.
Very happy with MPS+
