$330 for turning on daylight running lights and setting speedo to metric>normal cost?
I hope to buy a 2013 Porsche in the USA and export it back to Canada where I live. I will need the daylight running lights to be turned on and have the speedometer units of measure changed to metric and was quoted $330 by a Porsche dealer to complete this [will also get the recall letter for that]. I have had cars in the past on which those changes could be made by the owner as selections through the computer and wondered if that is not the case for a Porsche and the dealer is charging me for something I could do myself. I have never owned a Porsche and therefore am not familiar with the changes I can make through the computer or the costs of having the changes made through a dealer. Please comment if you know anything on this.
Thank you,
RET
Thank you,
RET
Perhaps I am missing something here.... but on my '14 C4S the LED DRLs are always on when the car is on. I don't recall if there is a setting for this in the menu or just set to on.
As for the speedo -- I thought both metric and standard are there? Are you looking to replace the speedo dial entirely with one showing only km/h? The digital displays can be changed to metric through the settings menus in the PCM.
I often drive from the UK to mainland Europe, and change all settings in the PCM each time so my odo reads in KM then as well as the speed.
Obviously does not change the clocks themselves but I can't imagine that you get that for $330.
I don't know about the daylight running lights as I thought they were on from the factory.
Changing from miles to km's is for sure a user changeable function via the PCM. If Canada requires you to change the analog instruments, you're in for a lot more than $330.
instead of buying a used vehicle from said dealer, you're importing from the US (effectively undercutting them). i'm not judging you as i have done the same but pay the man and get it over with. these are not PCM adjustments. you probably have to change the odometer reading and get the speedometer gauge face replaced. i'm surprised its not more than $330
Speaking as a former 996 owner that I imported from the US, you do not need to replace the gauges as long as there is the digital readout in KPH. As for the DRL, I remember on my 997 I could adjust through PCM. Can't speak to the 991.
There are lots of posts in the Rennlist Canada forum that could help you out.
In the 991 the US has the Daytime running lights on already. And you only need to change the digital MPH to KPH. This can be done on the TFT screen (vehicle options screen in the gauge cluster). The no open recall letter is easy for them to look up and complete for you. I have sold many vehicles to Canada and never charged a penny for this.
http://www.porscheprestige.com/en/se...rsche-vehicles
i do find it surprising that the existing analogue gauge would not have to be replaced but whatever...better for canucks!
Seems like the $330 is to get the recall notice completed, as all the other items are user-configurable with ease.
