TPMS reset
#31
I remembered this process being necessary, but I am having no luck. I've been stuck on the "No monitoring System is learning" message for 20+ mins. Hopefully the sensors that Apex Racing sent with my new wheels are actually functional.
The ignition merely needs to be 'on' I hope, and the car not actually running?
#32
#33
how long do the original OEM sensors last?
I am past 100.000 km and they still work fine.
Thank you!
Thank you!
#34
Assuming all TPMS sensor are generally the same-ish... The current ones in my Infiniti are approaching 13 years old / 125,000 and still working fine. A previous set in my wife's' Lexus lasted 11 years / 100,000 miles with no issues.
Schorsch (05-28-2023)
#35
Let us know how you get this sorted.
#36
#37
I have a 2017 C2S which was delivered with Pirelli 295/30R20 winter tires on its OEM wheels. Rather than dismounting those tires, I bought a set of OZ 20" wheels and Michelin PS4s tires [with 305/30R20 rear tires] from Tire Rack which came with TMPS sensors installed. After mounting the new tire and wheel assemblies, as soon as I started the engine I was confronted with the MFD lit up asking if I had changed the assemblies. I selected the summer 20" size and went for a drive and the new TPMS sensors became recognized after about 3 miles of low speed urban driving. I later reset the TPMS for Comfort settings which make a huge difference in ride quality and comfort on Ohio's many mediocre roads. Akron could qualify as "the automotive suspension durability test course of USA."
My car's MFD specifically states that the car must be driven for the new sensors to be recognized by the monitoring system. On my car, the module for that TPMS is located a short distance behind the right front wheel inline with the front subframe [crash absorption structure] and is plainly visible, labeled to identify what it is, and accessible when the front belly pan is removed.
#38
#39
Interestingly enough, it did register nearly instantly - I backed out of the driveway and the message was already gone. Makes me wonder if having it sitting with the key in the ignition does actually help learn the sensors in some fashion.
