Retrofit SPASM to PASM?
Old 08-29-2014, 12:46 PM
  #31
lunarx
lunarx's Avatar
Originally Posted by Skeptikal12
If you have truly driven PASM and SPASM equipped cars with equal tires and tread wear over the same surface back to back and noticed Aero differences with the different angle of the rear spoiler and then in the end managed to put % number on that difference - then you are truly blessed.
With the lowered ride height, perhaps the SPASM lip does help a very tiny bit and then gets balanced with more rear wing angle.
However, it is nothing that significant.
For anyone who thinks that is a big deal, How can you not have AeroKit Cup on your car?
Old 08-29-2014, 09:58 PM
  #32
BlackBeauty
BlackBeauty's Avatar
I have PASM and just got the lip - huge difference at speed, the car's front is planted, the way it was on my 997. Can't believe a $300 installed mod could make such a dramatic difference!!
Old 08-29-2014, 11:12 PM
  #33
StudGarden
StudGarden's Avatar
You mean the front lip from Suncoast?
Old 11-07-2015, 06:25 PM
  #34
Gem Mookherjea
Gem Mookherjea's Avatar
thanks to whoever recommend the SPASM lip, worth every penny
Old 11-07-2015, 06:54 PM
  #35
jimbo1111
jimbo1111's Avatar
Wow! I ticked the PASM-S when I purchased. I found that the 991 is far superior to the 997 I had in terms of handling . So different that it feels like a different car. Not even close.
Old 11-07-2015, 09:44 PM
  #36
dogshyne
dogshyne's Avatar
you can replace the pasm springs/struts with the sport pasm springs/struts. it is a much harsher ride... but it feels much more glued to the ground.
Old 12-09-2015, 07:35 PM
  #37
Dalema
Dalema's Avatar
Was anyone able to definitively determine the answer to this (or did it)?
Good string as I was under the misconception that it was just the springs.
Old 12-10-2015, 12:43 PM
  #38
Larry Cable
Larry Cable's Avatar
Received 3,457 Likes on 2,260 Posts
sadly I think the answer is no ...
I think we know the following:
its at least:
- springs
- spoiler lip
- reprogramming rear wing
it may be:
- stiffer anti-roll bars
it could even require:
- new shocks
- new PASM controller
I Think that about sums it up ...
If I were going to do this, I simply go with Damptronics and a TPC DSC and maybe their roll bars too
Old 12-10-2015, 01:48 PM
  #39
STG
STG's Avatar
As Larry noted, there's a lot more to it. Even if possible, it would be very cost prohibitive. I know there are different anti-roll bars for sure.
The only way to research the parts for it, would have to include two cars with and without the option and doing a search by VIN number with a Porsche Parts Dealer. Even that wouldn't give you all the answers most likely other than major parts.
Old 12-10-2015, 03:03 PM
  #40
Larry Cable
+1 and you need to know the I*** variant codes in PET to decode the parts lists
probably better off going with TechART/HR lowering springs (or fit the OEM PASM-S) a KW H.A.S or Damptronics for the full monty (& a DSC)
Old 12-10-2015, 03:07 PM
  #41
STG
STG's Avatar
^^^ yes!
The OEM route would be $$$$$$$
One option that's good to have on the build. Not an easy one like adding a duck! One on those that were on my must have list.
Old 12-10-2015, 03:13 PM
  #42
Larry Cable
^^^ yes!
I agree, if PASM-S had been available on the cabriolet or I had ordered a coupe PASM-S would have been a must have (along with a duck) on my options list.
I personally feel that for current PASM owners that want to "upgrade" their suspension, probably the most economic and easiest route is Damptronic
coilovers, and TPC-Racing DSC+anti roll bars ... should be able to do that
for around $4-5k ... and its an easy install, hardest part is shock replacement
and alignment.
Overall I think that would result in a better system for the $
Old 12-11-2015, 11:02 AM
  #43
Dalema
Dalema's Avatar
Thanks - good summary!
Old 12-12-2015, 02:06 PM
  #44
1analguy
1analguy's Avatar
Now, for the other side of the question: would it be just as much of a hassle/expense to change in the other direction...that is, to go from SPASM to PASM? I'm looking for a refined GT more than an aggressive/track car, and so in my search I have been passing over all of the cars that have the SPASM option...and there have been plenty. My guess is that it would be equally difficult, but I had to ask.
Old 12-12-2015, 02:34 PM
  #45
STG
STG's Avatar
More cars don't have SPASM than do. No cabs have it either.
Your search should be easy.
In reality, 10mm isn't going to make a world of difference. Your tire pressure and brand of tires will make more of a difference in ride comfort.
Quick Reply: Retrofit SPASM to PASM?
