Chrome front bumper
Chrome front bumper
How do you install the chrome front bumper grille? Is there somekind of bolt that I need to remove? do I need to remove bumper?
I think I could pull the wings off by force from the front, but in case I break them...
See the parts here from suncoast:
http://www.suncoastparts.com/product...or_Accessories
Thanks in advance for any help!!
PF
2014 991 C2
PF
2014 991 C2
Finally got it installed....
Easiest installation ever, but figuring it out is a pain since I didn't want to scratch or break anything.
What I learned is that these chrome front bumper grille is actually just a COVER of the real grill. The real grille seems un-removable unless you remove the bumper first. I was trying to pull out the real grille at some point, but stopped immediately after realizing that the whole bumper seemed to flex a tiny bit
So while facing the front bumper: you can see that there are two grilles on the left side and two grilles on the right side.
Let's start on the right grille first. You can see that there are left and right clips on the grille cover. You will want to push the most RIGHT clip of the grille cover first. You can also see that there is a hole that you put your hand in in the bumper (hopefully your hand is small enough). So put your hand inside that bum hole and push the RIGHT clip of the grille cover from the back first and slowly slide the RIGHT portion of the grille cover half way out (you can bend it a little). Continue to proceed with the pulling of the RIGHT portion of the grille cover and the LEFT portion of the grille cover will eventually detach by itself.
On the left grilles, the first clip that you want to push is located on the most LEFT side of the grille cover. Push that clip and slowly slide the left side of the grille cover until the right portion of the grille cover snaps out by itself.
Repeat and rinse.
Time to install: 10 minutes
Figuring it out: 3 days
Porscheforever
Repeat and rinse.
Porscheforever
Repeat and rinse.
Porscheforever
Repeat and rinse.
Porscheforever
My concern is that I would like to remove the grills to gain access to the A/C radiators. Do I just follow your "clip removal description"? (Haven't looked that closely yet.)
I'm confused. At first you say the grills (appear) to be un-removable, but the new chrome fits over them anyway. Later it reads like you were able to remove the grills ...."clips".
If you want to gain access to the A/C radiators, I think the only way to do it is by removing the bumper.
Porscheforever
The new chrome grilles are just a "cover" over the real grilles (like a holster over a hunting knife). The real grilles are not removable from the outside because they are attached to the inside of the bumper. The cover of the real grilles (the one that I replaced with chrome ones) can be removed from the outside without removing the bumper.
Porscheforever
Porscheforever
Porscheforever
Porscheforever
Just installed mine and love the look. The key thing to remember here is that the existing black grills are actually 4 covers that will be removed from their mounts for the chrome-edged new grill covers to slide & snap back onto. Also, there is a center catch/snap that must be released as you push the outside-most catch from the inside of the bumper cover forward and out through the front of the bumper cover. Afterward, gently pull forward from the outside and the inboard snaps will pop loose. Once one of them slides off, the rest of the deinstallation becomes very clear.
Installation is the reverse process with a light tap on the inside edges to seat and secure that area, then seat the outside edge. A gentle squeeze on the front center of the grill cover and the center post will secure that snap.
Hope this helps.
Hope this helps.
