Installed a SprintBooster in my C4S
Old 06-29-2014, 10:59 AM
chuck911
chuck911's Avatar
Originally Posted by Mondrian
You could fit a mechanical stopper behind the pedal, like a rubber bit fixed on walls (or floors) to avoid door banging the wall.
I think you're thinking of something else, like the kickdown button. What the Sprint does, let's say without Sprint with the pedal halfway to the floor you get 50% of full throttle. Its actually less than that, but nevermind. Then all the way down you get full throttle. Well with Sprint, with the pedal halfway to the floor you get 60% of full throttle. So more throttle for the same pedal travel. Makes the car feel more responsive. But then you get full throttle when the pedal is only at say 90%. Pushing the pedal all the way to the floor won't do a thing, Sprint was giving you full throttle already.
The factory settings (Sport, Sport Plus) actually do the same thing, only in a more sophisticated fashion so that you still have throttle control over the full pedal travel.
I got a Scuttlebutt Belgian Tripel 7 for anyone able to explain "more sophisticated fashion."
Old 06-29-2014, 12:23 PM
Galion
Galion's Avatar
Chuck, can you explain why with the SB activated, theres still a peceivable difference on how the car reacts on each mode? (std, sport, sport +)
Old 06-29-2014, 01:06 PM
chuck911
chuck911's Avatar
Sure. All SB does is feed the car a greater pedal movement than actually takes place. Its like, you move the pedal 5 degrees but SB tells the car the pedal moved 6 degrees. That's it. Now when you change from Normal to Sport, or Sport to Sport Plus, it does pretty much the same thing. So with SB you get the accelerated feed amplified by the accelerated Sport or Sport Plus mapping on top of it.
There's still more going on by the way. If every tiny little gas pedal movement translated into throttle input then all the little vibrations from the road or your twitchy foot would result in lower mileage. So Porsche builds in filters. SB doesn't affect any of that either. Still, by making the system think the pedal has moved more than it actually has, it will tend to defeat these filters. Part of the reason they say you may notice lower mileage. The other part being of course being the previously mentioned twitchy foot. But I believe it says on their website they haven't been getting feedback about lower mileage. This may be that buyers aren't that focused on mileage. Or it may be that they just learn to be more judicious with the throttle. I'd like to think its the latter.
Old 06-29-2014, 01:27 PM
Mondrian
Mondrian's Avatar
I understand how it works but what I was referring to was to put a stopper behind the pedal so as to shorten its travel to 90% (or wherever you reach max). So the mechanical max travel is reached at the same point as max throttle, then it's just a case of getting used to the the shorter travel.
Old 06-29-2014, 02:07 PM
jlanka
jlanka's Avatar
Originally Posted by Zohan
Need for Sprint booster - fail
need to say need for a Sprint booster fail - fail
Old 06-29-2014, 02:43 PM
Galion
Galion's Avatar
^^I find amazing that people that don’t own it seem to have the negative feedback and thats just plain weird..LOL
If anyone shows me one bad review of someone that actually installed a SB in his car, Ill give away two of Chuck's Scuttlebutt Belgian Tripel 7
Old 06-29-2014, 03:34 PM
Sask997
Sask997's Avatar
Would it be possible to simply change the sensitivity of the potentiometer that controls the throttle using PIWIS or Durametrics?
Old 06-29-2014, 05:27 PM
bccars
bccars's Avatar
I'm with zohan. Why the hell do you need a more aggressive throttle map for ? Less control ?
Old 06-29-2014, 08:02 PM
Zohan
Zohan's Avatar
If it is not broken don't fok with it
And it will affect your warranty
Old 06-29-2014, 08:58 PM
Galion
Galion's Avatar
Because the car feels more responsive hence more control. Love it!
I wish Id know before about the SB when I had a base 991, Damn! I'd would have kept that car.
Nope, no warranty issues, the P service guy said that as long as I dont touch the ECM we were ok. They even help me with the install.
I am curious...are you the guy in your avatar??
Old 06-29-2014, 09:32 PM
Zohan
Zohan's Avatar
No, His name is Kenny Hotz of Kenny vs Spenny
Old 06-30-2014, 09:26 AM
bccars
bccars's Avatar
Have you driven it like that in anger on a soaking wet twisty mountain road ?
Old 06-30-2014, 01:05 PM
Galion
Galion's Avatar
Have you driving it like that in anger on a soaking wet twisty mountain road ?
I have a 4S
Old 06-30-2014, 01:38 PM
DKC64
DKC64's Avatar
I had a Sprint Booster in my Mini Cooper before. That was definitely needed as the 1.6L petrol engine had a very bad lag with the throttle response. The sprint booster made it better.
Haven't really thought about the SB for my C4S but it may be a good idea to improve the "normal" mode!
Old 06-30-2014, 02:44 PM
bccars
bccars's Avatar
I have a 4S
They have the same throttle maps as the other Carreras, no ?
Quick Reply: Installed a SprintBooster in my C4S
