Warming up in Sport+
https://rennlist.com/forums/991/776515-oil-temp.html
In it there is some confusion, or perhaps open questions, about how sport+ impacts the thermal management system (this is separate from throttle mapping - all else being equal an engine running at 4000 rpms, or idle, should warm the oil at the same rate in sport+ or normal mode; it's the mode's impact on cooling the engine that is of interest). LexVan in particular asks if he should be running in normal mode to heat the oil fastest. I've certainly noted that the oil generally runs cooler in sport plus vs. normal, which leads to the question of whether or not sport+ changes the thermal management settings at warm up, slowing the process. The (limited) data suggest that this is not the case.
Now, this test was done on a 3.4 engine. LexVan has a powerkit on his C2S, which includes an extra radiator, so he may see different results.
Having done it, it is worth pwning the LIN bus to avoid having to hit the Sport button every time I start the car. (If you have to ask, you don't want to mess with it.)
Since I normally drive in PDK auto mode, I wouldn't want Sport+ to come on automatically, though -- just Sport. And I don't think it's valid to compare the warmup behavior of the various modes by letting the car idle.
Doesn't the oil return get redirected and circulated through an oil cooler (or maybe an "extra" oil cooler or something) in the front valance(s) when Sport+ is engaged? I thought I remember something about that.
That might explain the warmer temps at 5, 10 and 15 minutes because there's no air flowing through the valance opening and cooling fins if you're sitting there idling for 25-ish minutes.
Nice test, but if there is an oil cooler involved in one of the samples and not the other, you lost control of the variables.
