Used Oil Analysis On 991
#61
What's the deal with the techron injector cleaner before doing an oil change?
also is it even needed on newer cars and with modern gas has cleaning agents already like shell?
#62
Received 5,388 Likes
https://rennlist.com/forums/991/8273...rate-plus.html
https://rennlist.com/forums/991/9332...dditive-2.html
#63
I forgot to update this thread from my Fall 2016 oil analysis. I'll update again in about a week, because I just had my oil changed again for the 40K service at almost 43,000 miles.
All is good as expected. Ran a full tank of fuel treated with Techron before this (and every) oil change. Wear metals are low-low-low (half of what you usually see posted around here). Viscosities seem a little low, but well within grade, and I did a lot of extended & higher RPM runs on a few of my fall country road runs before hibernation.
#64
Damn, I just had 1st change done and forgot to take Blackstone kit in when I dropped car off (also to have recall addressed). Next time. Always find the analysis interesting. Thx for posting yours.
#67
Originally Posted by randr
Lexvan - does your car see track usage? If so can you comment as to amount of time etc. Thanks
#68
Originally Posted by evilfij
Are you using blue label or red label 5w50?
#70
#71
This picture by Duke I is highly LexVan approved:
#72
Another very good UOA from 2 weeks ago during the 40K service. Low-low-low wear metals.
#73
Got my second 5W-50 analysis back from Blackstone at 15K. Looks great. I have abused the GTS in the mountains of NC and enjoyed it as did the car. We are doing everything correctly and the 991.1 GTS is cooperating likewise.
#74
