Lease Rates
Copied from IRS page for passenger automobiles. . .
http://www.irs.gov/publications/p946...link1000107703
For 2013 Yr1 $11,1601, Yr2 $5,100, Y43 $3,050, Later Years $1,875
For Trucks and Vans. I don't think Audi Q5 is heavy enough so the Macan probably won't. Not much of a difference anyways.
For 2013 Yr1 $11,3601, Yr2 $5,400, Y43 $3,250, Later Years $1,975
Rallybagger it seems your money rate is a bit inflated but the residual your being quoted has to be a mistake and if you can get it I would pull the trigger before your dealer wakes up. But that deal is way below reality unless your paying msrp to 3% off msrp on the car and they are making it up elsewhere .
I thought the residuals were set by PFS and the dealer cannot change them. For a C2S with pdk I think your's would be 71%. But not 100% sure for April / second quarter. Check out this forum - http://forums.edmunds.com/discussion...-questions/p37
I believe Tier 1 MF is 0.0020 currently.
I think either the salesperson made a mistake or will tell you this and then change it when it comes to signing - so make sure you double check it if they say they can do it.
I would agree that the C2S rates are lower than the C2. I also think rallybagger was doing 24 mths. As I said I'm not 100% sure for April.
Best to ask on that forum or just call 2 different dealers and ask what the residual is - it's set by PFS. There's a few sales folk on this forum too - maybe they could quickly look it up.
Edit: one other thing to bear in mind is that you may trip the MRM depending on how the car is optioned. I think it is around $119K on the C2S (?).
2014: 68%
2015: 66%
I think for 10K you would add 3%, so 2014 would be 71%.
Add 1% for MT
Subtract 2% for 27 month lease
