Redline limits
These numbers are for the Turbo S, which only comes with PDK.
Gear Ratios:
1st – 3.91:1 (7200rpm = 43mph)
2nd – 2.29:1 (7200rpm = 74mph)
3rd – 1.58:1 (7200rpm = 107mph)
4th – 1.18:1 (7200rpm = 143mph)
5th – 0.94:1 (7200rpm = 180mph)
6th – 0.79:1 (6625rpm = 198mph electronically limited)
7th – 0.62 (5250rpm = 198mph, electronically limited, and possibly drag limited lower)
Diff: 3.44:1
Source: Road & Track.
Gear Ratios:
Diff: 3.44:1
Received 5,413 Likes
I always thought this info was in the back of our owner's manuals? Did you look there?
Both manual and PDK gear ratios can be found here: http://press.porsche.com/vehicles/12..._911_Specs.pdf
Doesn't show speeds but note 1st and 2nd are the same as the Turbo S listed above. Add a few mph for the higher redline. Even better, floor it and let us know what you get.
