Remote start for 991 PDK?
Suzy (via iOS app)
Received 5,388 Likes
If you want a Porsche that blows hot air fast, get an aircooled 933 for example.
I need a remote start. I have a short drive every day (about 3 minutes).
It takes the car 10 minutes to warm up...when I say warm up... I mean that the blowers are sending on hot air so that I am not driivng to work with the wipers and and windows fluid constantly spraying. I have used de-icer on the outside windows etc, but they will still freeze.
In the past I have gone out, pressed unlock 1 time to open drivers door, started the car and then closed the drivers door and manually closed it by using the mechanical key inside the fob.
It is exceptionally annoying. I won't wait 10 minutes every morning to drive for 3 minutes. I will also not go outside and inside again to manually unlock the car. I also have neighbors, so I cannot go outside and redline the engine to get heat into it!
http://www.viper.com/SmartStart/
This is what I want for my 991 - the ability to start the car from iphone and wifi etc. I want it to be on a schedule, so the car starts by itself at 7am, runs for 10 minutes and then stops. When I go outside at 7:15am the car will be warm and no ice = no problems.
I actually thought it was the no cost option for the wife/gf under the order code: MAN
http://www.viper.com/SmartStart/ This is what I want for my 991 - the ability to start the car from iphone and wifi etc. I want it to be on a schedule, so the car starts by itself at 7am, runs for 10 minutes and then stops. When I go outside at 7:15am the car will be warm and no ice = no problems.
Does Issa still own that company?
Sent from my iPhone using Rennlist
