PSE retrofit pricing
My preowned car had everything I wanted except for PSE, can anyone who has had it installed at the dealer (including the switch) comment on what it cost out the door? Thanks!
I know there are other alternatives but I want to keep it factory. I have a base car, I think it's more expensive on there, so specify if you can.
Folks here have described parts plus dealer installs ranging from $3200 to $3600. Be sure to get the console button and the correct factory operating sequences.
The base car is more expensive. You'll need:
- new exhaust tips
- new PSE center section
- vacuum hoses
- vacuum actuator
- harness for the vacuum actuator
- programming to activate the actuator
- new side mufflers
- console switch
An S without PSE just needs:
- new center section
- vacuum hoses
- programming
- console switch
I bought the kit from Suncoast for my 991 C2S for ~$2600. Everything that was needed came in the package. Muffler, exhaust tips & new switch panel (the entire panel gets replaced, not just a switch). Paid my local dealer $800 to install. Great upgrade.
It's $400 more for the non-S cars from Suncoast -- $2995. Local dealer said $4100; 8 hours labor at their rate is $1032 so price seems in line.
