Spacer question...
I need to get off my lazy keister and install my spacers! Looks great. Which brand did you go with? Do they bolt onto the hub, or is that just holes to access the brake retaining bolts?
Thanks...went with what Suncoast had.
My car already had the factory black bolts & silver front spacer, they could match that...plus supplied the positoning tool.
FWIW, looks just like H&R stuff...the two screws do hold it on, but this is the first time I've ever done it & would suggest isn't necessary.
Great Pics! I have Sport PASM (and PDCC), and have the 5mm spacers all around. I'm thinking of the 15's for the rear after seeing these pictures. One question: with the change in the rears do you feel the 5's on the front are enough?
5's or 7s are fine in front just wouldn't do anything more. We usually do 15 in the rear.
