Break-in Oil
Old May 20, 2013 | 06:44 PM
DKC64's Avatar
DKC64
Default Break-in Oil
This may have been covered in the forum but I can't seem to find the answer.
In the 991 from the factory, is the engine oil the standard Mobil 1 0W40 or does Porsche put in some special "break-in oil"? My dealer seemed to tell me that the oil is special and that changing the oil early (say ath 2000miles) is not good for the car.
Thanks!
Old May 20, 2013 | 06:51 PM
rnl's Avatar
rnl
A40 spec mobil 1 0w-40 in mine.
Old May 20, 2013 | 07:01 PM
Jerry991's Avatar
Jerry991
My understanding is that there no longer is any type of break-in oil so no need to change early.
Old May 20, 2013 | 07:36 PM
Dr.Bill's Avatar
Dr.Bill
oops
Old May 20, 2013 | 07:47 PM
John's 991's Avatar
John's 991
Its just standard Mobile One 0/40 and there have been lots of posts about when to change it. Porsche recommends after 10,000 miles or 12 months. Lots of "old school" folks, me included, like changing it earlier. I changed it at 2,500 miles. This can't cause any harm, but might be wasteful (the oil is expensive) and "less green."
I had the dealer change it after a year a second time. They charged $250 whereas I think the oil and filter cost me about $80 when I did it myself. Here is a link with more info:
http://www.porscheownersmanuals.com/...Topping-up-oil
Old May 20, 2013 | 08:16 PM
DKC64's Avatar
DKC64
That's what I thought and I'm old school as well so planned to change it at around 2000miles. The reason I asked is that when I asked my service manager his answer implied that the factory oil is different and that early change (before 10,000miles) is not a good idea.
If the factory oil is just plain normal Mobil 1 0W40 then other than "wasteful" I can't see why not to change at 2000miles.
Old May 20, 2013 | 09:13 PM
chuckbdc's Avatar
chuckbdc
I too am "old school" - had mine changed at 3000 mi and intend to do so every 10K or 12 months in the future. My dealer charged me cost (oil and filter and washer are $80 DYI so he got me for a bit there) and 1 hour labor- which I thought quite reasonable. I DYI'd most everything on my Porsches for 40 years and the 991 is so easy I felt guilty. Bu not so guilty that I won't let them do it again.
Old May 20, 2013 | 11:51 PM
Hammer911's Avatar
Hammer911
spoke to my service tech a couple weeks ago when I hit 2500 miles on mine. He recommended NOT changing the oil. I drive my car a fair amount, almost daily. He suggested if I felt like I absolutely thought I needed to change the oil earlier than the recommended interval I should just plan on doing it late in the fall since it is more likely to sit extra days if the weather is bad during the winter.
Old May 21, 2013 | 01:01 AM
DrJay's Avatar
DrJay
It has always been my understanding that oil used during break in should be changed because as the engine wears/beds in/breaks in/whatever term you want to use, it causes little pieces of metal to come off and into the oil that then get circulated around the engine therefore changing it often and early during break in was a good idea.
Is that not the case anymore?
Old May 21, 2013 | 11:02 AM
Hammer911's Avatar
Hammer911
Given the quality of the milling equipment these days, tight manufacturing tolerances, and the fact that they run these motors pretty hard in the factory, it must not be an issue anymore.
Old May 21, 2013 | 11:42 AM
neanicu's Avatar
neanicu
I really don't understand why some people think or are led to believe that they shouldn't change the oil during break in or as often as possible for that matter. Having fresh oil in an engine is a good thing,if you can afford it,change it often. Having fresh additives in an engine,especially during break in is an advantage not a disadvantage.
SOME service advisors(and please observe I'm emphasizing the word '' SOME '') are merely salesmen and are no different than the one that sold you the car,in which category you can find SOME that don't know the difference between a Sport Chrono car and a Non Sport Chrono car for example. Please do not take technical advise from them.
If you want to speak with someone qualified,try researching for a good experienced technician the dealership might have and speak with him. And by experienced I mean Porsche Factory trained with a good reputation,no oil change,tire rotation etc kind of '' technicians ''.
Old May 21, 2013 | 12:00 PM
John 996 TT Cab's Avatar
John 996 TT Cab
Re the comment about the engines being run pretty hard at the factory. This is incorrect. They only run a very small % of the engines at all. All testing done on a "dry" basis without starting the engines for a test. At least this is what the Factory guide person indicated on 3 different tours of Zuffenhausen factory in 2012.
Old May 21, 2013 | 12:14 PM
Hammer911's Avatar
Hammer911
good to know. thx. (plus I'm jealous...three tours in a year?!)
Old May 21, 2013 | 12:27 PM
Hammer911's Avatar
Hammer911
I don't disagree with you, and am lucky enough to have a service guy i trust explicitly, implicitly and everything in between. He spent ten+ years under the cars, factory trained, I guess 6 or 7 years now as an advisor. You are right - this is the kind of guy everyone should have access too.
Regarding the oil change, I suspect one of the things that has evolved with all the tech developments over the years is what constitutes "fresh" oil...at least in these cars, I'm not concerned that changing it at 5k instead of 2k will make a material difference. My 964 and 993 were a different story for sure. Happy motoring!
Old May 21, 2013 | 01:19 PM
Cogito_Ergo_Zoom's Avatar
Cogito_Ergo_Zoom
Aiiiiiiiiiiiiiiiigggggghhhhh.....anooooother oil question!!!
