Wireless OBDII with 991
Has anyone tried any of the wireless OBD2 (OBD-II) transmitters out there on the 991? I'm wondering if any of them work with Harry's Lap Timer.
I am trying to hook up my valentine ONE through Savvy (OBD II). The OBD access is limited due to the incorporation of the OBD II within the fuse box. The entire area (OBD + fuse box) is covered by a large lid. Is anyone using the OBD II (Savvy) in 991? I am curious to see a DIY.
@John991. Do you have a picture of how you hooked up the GoPoint BT1?
Hi Kim F
I don't have a pic but I just take the cover off and plug in the GoPro. At the end of each session I unplug and remove it. At the end of the day I put the cover back on and drive home. It is a bit annoying to have it sticking out of the fuse box but as long as you are aware it's there it's easy to avoid it when getting in and out.
If I wanted to leave it in more permanently i would get a second panel and use a dremel tool to cut out a hole for it.
The fuse box lid seems like a bit of a problem. I'd suggest ordering another cover 991.555.621.00 then cutting it to go around the OBD port, or around the whole bluetooth plug-in. Then I'd get some hobby glue or silicon or bondo and fashion some sort of "kick plate" by gluing a pyramid shape or a triangle of sorts to protect from shoes going in towards the pedals (or lifting out past the box when exiting the car.)
I have been looking for a more flush/flat OBD II connector so that I don't inadvertently kick it loose.
@Carrera GT. Thanks for the part number.
If I can locate a wireless OBD II connector that is flat or compact, I would be set.
Now, were was I?
Oh yeah ... the customer always comes last.
Anyway, looks like there are some maybe options for an OBD2 connector.
https://www.google.com/search?q=flat...=lnms&tbm=isch
http://www.google.com/imgres?start=1...6&tx=102&ty=85
![](http://i00.i.aliimg.com/img/pb/598/447/367/367447598_119.jpg)
http://www.google.com/imgres?start=2...30&tx=76&ty=82
![](http://i00.i.aliimg.com/img/pb/184/330/470/470330184_361.jpg)
http://www.google.com/imgres?start=3...6&tx=79&ty=110
![](http://www.cardiag.co.uk/upload/pro/wifi-obdii-car-diagnostics-tool-for-apple-ipad-iphone-ipod-touch-03.jpg)
![](http://www.tradeeasy.com/photo/seller/y/710526/sell-lead/graphics/1324968546004_AOT-210.jpg)
http://www.tradeeasy.com/supplier/71...tic-cable.html
Actually getting one of these ordered from these places can be a trick. I've used alibaba and it was okay. I have a credit card with a very small credit limit just for these kinds of purchases, just in case.
Anyway, I think if you fiddle with a search for diagnostic cable or OBD2 variations on the description, something will be available.
Thinking about adding the GoPoint to my (new) Harry's setup. On their site but can't figure out what the difference is between the BT1 and BT1A, other than the price of course.
Anyone know?
Anyone know?
do you guys have videos of the obd2 data overlay?
I tried using mine but it was only showing throttle & RPM data not brakes or steering. Anyone have any idea how I ge braking & steering data?
http://www.youtube.com/watch?v=m295O...ature=youtu.be
OBD II does not monitor or report brake pressure or steering angle data. It's mainly engine and exhaust related data. You'd need to add sensors for both. I'm sure you could find an answer about the viability of doing this with HLT on his forum. He's usually pretty quick to respond if you can't find anything that's already documented.
