H&R Springs Installed
pasm 10mm
spasm 20mm
H&R =30mm
the new gt3 is -30mm as well
go for some 15mm spacers front too. youll thank me..
i did 20mm all around and it was perfect... same spacers from my Cayenne. lol
spasm 20mm
H&R =30mm
rears are literally no effort at all, its the fronts that suck.. gotta remove caliper... pop the joint and remove the hub.. then shock comes down and out..... it's just really tall and hard to get the right angle.. without a fender it would be 5 minutes for the fronts..
alignment should be 200.. labor for springs. 300, springs 250.. so 750-800 all said and done.
just searched and tirerack had increased the price since back when i had 991.. i actually had the first set for the 991 and was kind of a trial set..
i will make some emails and see if i can get a rennlist GB or something via H&R..
Contacted h&R. Msrp is actually 549 for the springs. Cost is like half off. Can do 45% off plus ship if anyone needs a set. Just PM me and I'll forward you to my guy.
I think 250 is kind of optimistic, this is the guy that helped me and gave me the best price that i could find.
cheers and good luck
Tam Nguyen
SUPREMEPOWER, CA 92870
Tel: 714-632-1951 ext 224 | Fax: 714 632 9249 | Mobile: 909-539-5240
Email: tam@supremepower.com | AIM: supremetam
Websites: www.supremepower.com | www.supremepoweroem.com
Tam Nguyen
Tam Nguyen
Tam Nguyen
Just waiting for my cf rear diffuser and new badging from Eric and I think
I will be set for a while!
