Cold-Blooded Engine it seems
Interesting topic, Gary. I'll pay more attention to the exact mileage next time I drive my cars.
Once the water temp reachs its stability target, the oil temp starts rising abruptly. It rises 15° to 20° F for each mile after that. Since the engine workload hasn't increased, it's best to think of that as 15-20°F per minute instead. Finally, the oil reaches something around the same 200°F about the time my attention was needed elsewhere so I didn't spot where it stopped rising. From previous observations, I'd say it stopped rising around 185-190°F and stayed there until I began asking more of the engine. Thereafter, the number of degrees of oil temp above 190° seems to be proportional to how hard I'm working the engine, with a max of about 225°F on a warm day running close to maximum power for several miles. (viz track conditions.)
I didn't have occasion to explore the issue of the oil cooler that engages with sport mode.
Obviously, Porsche have done something that intentionally moves the heat into the coolant preferentially until that comes up to the temperature that other subsystems are designed to expect. Very interesting.
Incidentally, with the small size and relatively low cost of temp sensors I wouldn't put too much attention on placement of the temp sensors. I can't confirm their competence, but I presume that Porsche chose placements that give a result that is representative and most consistently useful for evaluating the engine's condition. I certainly would, so I grant them the same foresight.
Gary
driving today at 50* my coolant temp hit 180 in 3-4 minutes in the atom, and oil temp didn't reach operating temps for over 10 minutes.
Gary
With respect to auto engines, and in the absence of CHT probes & gauge, utilizing oil temp for the purpose makes sense to me.
Ken
Ken
Just curious, did Porsche include a cylinder-head-temperature gauge in the early air-cooled models?
Gary
Gary
PS I did a cruise in normal and sport modes and can verify that going to sport lowers the oil temp. So clearly the oil is getting routed through a cooler in sport mode.
Virtually all the heat an engine makes is combustion waste energy. The vast majority of coolant flow goes to dissipating this heat from the cylinder heads. (The real reason by the way Porsche went to water cooling, they couldn't continue designing powerful, efficient, low emissions engines within the design limitations imposed by air cooling the heads.) So you start the car and right away combustion is heating the heads and the coolant in the heads.
Not so much the oil though. Because, while coolant is channeled to dissipate heat, oil is only pumped where its needed for lubrication- and as its needed for lubrication all the time, its pumped all the time. Coolant, meanwhile, is controlled by temperature. Very little flows below a certain point, while maximum flow is only attained under conditions of high ambient temp and full engine load. There is in other words a great deal of coolant overhead capacity. The distinction here perfectly explains the varying temps, with no computer and just one rheostat.
There is maybe one detail to fill in, just to make everything crystal clear: the reason oil temp seems to rise faster once water temp has stabilized.
Remember the coolant overhead capacity? Once 200F is reached, the reason it maintains steady at 200F is not that the engine heat output is steady, but that coolant flow is able to increase by whatever amount necessary to hold 200F. Excess heat however is also being conducted away via pistons, con rods and crank- none of which are water cooled, all of which are now rapidly heating the oil.
So, at this point the engine is warmed up- as far as Porsche is concerned anyway, or they would have chosen some higher water temp set point. QED. But we're continuing to drive and while the coolant flow is free to increase by whatever amount necessary to maintain 200F, the oil flow is not, and so naturally enough it starts getting hot even faster- at least that is until it begins to approach whatever temp equilibrates with load, ambient temp and, apparently, Sport setting.
Gary
A bit more after a chat with a Porsche service tech: there are 9 computer controlled modes for routing water and oil for thermal management on the 991, mostly but not all related to emisions control.
Back when I was reading everything they had on-line I could have sworn somewhere it said they use 7 different electric oil pumps. But last night, only found one reference to thermal management that mentioned "an" electric oil pump. I'm sure they must use more than just one.
