is there a way to disable the hill-holding feature
#46
You may want to consider this if you don't have FAL on your car from the factory:
https://tagmotorsports.com/techart-n...system-for-991
cheers!
#47
It should be roughly 5.8" at the bottom front plastic lip for an SPASM car, and 3.95" ground clearance under the chassis. Approach angle is 11 degrees per factory specs. Do a search here and you'll find a number of photos.
cheers!
cheers!
#49
Maybe I should have said the hill hold feature is like giving a 10 year old nephew his own hand brake that he can play with when ever you come to a stop.
