Wheel spacers on the 991
Old 12-17-2012, 02:06 PM
  #31
chuckbdc
chuckbdc's Avatar
duplicate post sorry dont know how to remove
Old 12-17-2012, 02:19 PM
  #32
limey940
limey940's Avatar
Originally Posted by chuckbdc
The car came with factory Sport PASM suspension and 5mm spacers. It is 20 mm lower than non PASM, 10 mm lower than PASM, via shorter stiffer springs; stiffer sway bars. I have no idea what the measurements/rates are or how they compare to aftermarket items.
Got if. I think tech art has a kit, I'm also going to ask
the dealer. I like the stance an reduced wheel arch
gap on the 991. would just like to see it a bit lower
like the sport PSM equipped cars
I posted some before and after pics ou spacers in this forum a few weeks
ago of anyone wants to see pics, just search
cheers
Old 12-17-2012, 03:19 PM
  #33
ArashApollo
ArashApollo's Avatar
Spacers decrease camber
Old 12-17-2012, 04:53 PM
  #34
chuckbdc
chuckbdc's Avatar
how?
Old 12-18-2012, 01:54 AM
  #35
chuck911
chuck911's Avatar
how?
I'm stumped.
Old 12-18-2012, 09:20 AM
  #36
mtony
mtony's Avatar
It doesn't.
Old 12-18-2012, 10:27 AM
  #37
chuckbdc
chuckbdc's Avatar
Originally Posted by mtony
It doesn't.
Ah.
Old 12-18-2012, 03:44 PM
  #38
ArashApollo
Oh sorry! Thought it did after a lot of forum discussions on the370z forum I still use. People there said it adds a bit of negative camber. Thinking about it now I take back my statement, as I don't really see the angle of the tire changing, just pushed out a little. Maybe the distance between the axle and the wheel may change the angle a bit when there is heavy load on the tire? But if so changes would be negligible.
Old 12-18-2012, 04:21 PM
  #39
ThePartsMan
ThePartsMan's Avatar
I will have mine installed later next week. I will post pics when completed.
Old 12-18-2012, 04:38 PM
  #40
cksuen
Cruisin'
cksuen's Avatar
Wheel spacers will result in a wider track. With a wider track, there is an increase in the resistance to weight transfer for the same cornering force so the car might roll less and you might need a bit less camber. However, with a 5mm spacer, I think the differences are so small that it may not make a different in real life.
Old 12-18-2012, 05:15 PM
  #41
limey940
limey940's Avatar
Default Here are my before and after pics
7 mm front, 15mm rear, poics dont really do it justice.
Im thinking of some springs to give it more of the sport PASM stance, maybe drop the front 1.25" and the rear 1" to reduce the fender gap
Old 03-13-2013, 10:29 PM
  #42
yxc145
yxc145's Avatar
I am not sure what you said it correct. I just checked the Porsche USA site. There is only one PASM Sport suspension, which lowers the car 10mm than regular suspension. I did not see any other PASM suspension.
H&R has springs that lowers about 25mm.
Old 03-13-2013, 11:00 PM
  #43
Dyim
Dyim's Avatar
Received 1,032 Likes on 553 Posts
Chuck is right. 3 suspensions.
Regular
PASM 10mm lower than regular
Sport PASM 10mm lower than PASM
Old 03-14-2013, 12:07 AM
  #44
yxc145
yxc145's Avatar
Regular
ok. just double checked. that is only on Regular Carrera.
Regular PASM is not an option on Carrera S. Does it mean Carrera S already is on PASM?
Old 03-14-2013, 12:34 AM
  #45
fester
fester's Avatar
I got them ...factory fitted...and they look great!
Quick Reply: Wheel spacers on the 991
