Fun Facts about the 991 (please contribute)
#196
It appears 20" wheels are the only option for cars with RAS. I was looking into getting a set of 19" wheels/tires with an autocross setup and finally figured out that you can't put 19" wheels on a 991.2 with rear axle steering... the inside of the wheel barrel would collide with the steering mechanism.
Thank you to Tire Rack for your configurator prompting me about RAS. I already knew getting a cleaning cloth between the barrel and the lower piece of the RAS knuckle was tough so it should have occurred to me sooner. There's probably only a ¼" or so clearance with my 20" wheel.
#197
#198
The Tire Rack site only shows 20" wheels if you select RAS, but will show 19" snd 20" is you select no RAS. But they only carry a few brands.
So I've poked around the forum some more and found this thread: https://rennlist.com/forums/991/1042...selection.html. Someone there is saying Forgeline makes an option that will work so it seems I'll have to look around at a broader selection before I give up.
BTW, the biggest reason I was looking for 19" wheels is the RE-71R don't have a 305 size in 20" tires, but they do have 19". If it comes to it I can just use the 295s... but I was already having trouble with spinning the rears as it was with all of the torque in the 991.2. I may just have to learn to feather the throttle a bit more.
#199
Not to highjack the thread, but y'all might get a kick out of this: My wife and I were driving from Brenham, TX to Houston, TX Saturday night in pea soup like fog with the rear fog light activated. Before we got out of Brenham, we were pulled over by local police for a, "strange issue" with our brake lights. Of course the issue wound up being the rear fog light. After I explained what the officer was seeing, turning the rear fog light on and off three times with various brake light activations, I was being thanked for my time and patience and told to drive safely home. "Twenty-two years on the force and I've never seen anything like that" the cop said to me as he shook my hand and walked back to his cruiser. I've been using rear fog lights in bad weather conditions consistently since 1996... ...I always figured they were at least common knowledge to law enforcement.
#200
You gotta love these cars!
#201
If you have the e-brake on, you don't have to release it prior to backing up or moving forward. Caveat is that you have to have the door closed and seat belt on. So, you don't have to worry about manually releasing it and no worries if you forget, it will release automatically.
#202
Yes. It’s a rear fog light. If the car is equipped with front fog lights, those will turn on at the same time.
#203
#204
ndfin (08-06-2023)
#206
To adjust the projected height of the headlights on a 991, there is a black rubber seal behind the small panels in the frunk. Open it and access the 5mm hex with a 9 inch long 5mm Allen wrench.
#207
If you have keyless entry and ventilated seats that are active, and you shut off the car and don’t go too far away from the car, the ventilated seats will come back on when you restart it. Not sure if it is distance or time dependent or maybe both?
Stopped at the fish monger (really small place in a strip shopping center), parked right next to the door and when I left the seat ventilation was active.
Repeated it when I got home just to make sure I wasn’t imagining things.
I admit I have not tried to see if this is mentioned anywhere in the manual.
#208
Brilliant forum. I've just read all 207 fantastic contributions, learnt so much. I've got electric mirrors which retract when you lock/unlock the car. I also like to 'down' the passenger side when parallel parking against a kerb. But I can't get my head round how to get them back afterwards to their original setting. Can someone talk me through the moves. Can you preset on the door memory pad, 1, 2 or key, to quickly revert to normal? I seem to have to reset mine every time. Thanks.
