RAS versus tire selection
In looking at the Carrera T for a do-it-all daily driver/autocross/track car, it seems like there are real benefits from RAS. But, in looking at the TireRack site, it looks like RAS requires 20" wheels. This seems to be confirmed by the configurator in that you cannot select 19" winter wheels if you have RAS.
19" wheels open up tire selection. (i.e RE-71R).
What is the better trade-off? RAS and stick with tire selection with 20"? Or, forgo RAS for the possibility to fit aftermarket 19" wheels with wider tire selection?
Thoughts?
Thoughts?
Thoughts?
Thoughts?
A number of 991 GT3 drivers (with RAS) are using 19” wheels. You need to take care with wheel selection to insure clearance. PCCBs create similar issues and can also be cleared with the right wheel, though stones getting caught between the caliper and wheel barrel are a real concern.
On the autocross RE-71Rs are significantly faster than MPSC2s and have a higher treadwear rating to boot (sometimes moving you up a class). The smaller OD is also good for gearing. Overall I believe they (or Hoosiers, obviously) are worth more time than RAS and MPSC2s. Against the clock I’d personally go with RAS and 19s, but as a second choice I’d take 19s and tires over RAS.
I see this posted a lot on this forum, but I only see four tire choices for 19" tires, none of them are RE-71, nor are any Michelins available:
https://www.tirerack.com/tires/TireS...SortCode=58100
In 20" there are nearly 20 tires to choose from:
https://www.tirerack.com/tires/TireS...SortCode=60158
For autocross and track work it’s ok to deviate from the stock sizes if you’re careful. 245/35 19s and 305/30 19 are the obvious RE-71R sizes to maintain balance. They will lower the car slightly and handling will change fractionally due to the change in roll center heights. Because the difference in rolling diameter is maintained ABS and traction control will still work as normal, while the lower overall OD will lower gearing slightly. Perhaps less necessary for the big track given the 20” options, but for autocross access to faster tires (RE-71Rs, Hoosiers, etc) makes this very worthwhile.
Thoughts?
Thoughts?
It's so seamlessly integrated that the 991 with RAS feels smaller, more responsive to steering input and makes the car feel and behave like a much smaller tossable car.
To forgo such an amazing addition just so you can put 19" winter wheels on in my opinion is silly.
OK so the winter 20" are a bit more $$ (were talking 6/8 hundred here).
The wider winter tire handling differences are also minimally invasive, I've got 295's on my Cayenne no issues at all! got 295's on my 991 4S, also no issues at all.
The same reason you're getting a getting a Carrera T is the same reason you'll want RAS.
It will really complete that car (should really come included in standard package on the T).
Wheels are changeable...
RAS, if you didn't get at build you won't ever have it.
Thanks for the perspectives.
To clarify, I'm not considering the tradeoff to allow for winter tires. Luckily, I live where I can run summer tires year round. I was just using the configurator winter option as confirmation that 19" wheels with RAS is incompatible or at least more difficult.
