Any update on wind buffeting issue?
I took my second long test drive last weekend and love the car. My primary concern is the wind buffeting issue at high speeds with the windows down that I read about on this forum. I would definitely track the car and if this issue can't be resolved it would be a deal breaker. And though I have no interest in a moon roof I would consider one if needed to abate the wind noise issue.
You are making a mistake judging a car that only has 2 windows because of buffeting ... my C6 Corvette Coupe had it even with the targa roof off, my 2008 911 Coupe had it as well ... unless you can get the air to escape from the rear windows which is impossible since they don't open your screwed... the Corvette had this weird screw thing I bought that allowed me to keep the glass hatch slightly opened and that eliminated it but the car looked weird with it ...
My advice ...Stop worrying and buy the car ... if a coupe's rear windows don't open this is what your going to get ... otherwise go for the cab where you can open the rear windows and then you have no buffeting !!
mine is horrible with windows down (sunroof delete model)......
i have to have windows half up to not have a horrible sound... which means i ride windows up all the time (annoying because i like to drive w/ windows down)
I find in most cars you are going to get wind buffeting with the windows down at speed. And if you are doing track why would you have your windows down anyway? Best to maximise the aerodynamics of the car at high speed and windows down is always going to make big noise too. That's the beauty of having a sunroof that you can pop at the rear....if you feel you need to vent the car at any stage without creating a lot of annoying noise inside the cabin.
I drove the car when the weather was a bit cooler, so the windows were up the whole time and I didnt get to find out how bad the buffeting was. But if its as bad as everyone seems to be saying, Porsche really needs to find something in the design to change, unless a simple add-on could fix the issue.
I personally prefer having the windows down versus running the AC, and would be rather irritated to have such extreme buffeting. Ive owned many two door cars and never run into this problem, so its hard to see why Porsche would not have noticed it.
So just to experiment, I left my top up and rolled just the front windows down going down the freeway. No buffeting.
This sounds like something Porsche needs to address. Especially since these cars are used on the track. Since they are piping noise into the cabin, they should be able to pipe air out.
Both the local PCA and BMW clubs require that the windows be down. The same applies for other lapping venues I participate in so it is not a voluntary issue. Have not had this issue with my e92 M3 up to 155mph
on the track. Need to do another test drive with the windows down at speed.
my exige/cayenne/997.2 never made a noise... the 997.2 would however if sunroof fully opened w/ windows up... proper design can alleviate all buffeting.
Isn't it true, though, that -- generally speaking -- the more aerodynamic the car, the more likely it is to experience buffeting when the shape is disturbed by open windows?
I don't recall any buffeting in the famaily Volvos growing up, because they were bricks moving through the air. Any modern shape I have owned, however, has buffeted.
I'm sorry, but what is exactly the point of high-speed driving with windows down? And what do open windows and track driving have in common? In my opinion, buffeting with windows down is the last problem to worry about. But since so many people are concerned maybe I'm missing something?
The reason you are required to drive with the windows down is in case of an incident you can be pulled out of the car. It is standard in all the driving venues I participate in.
