Question about the auto start/stop
How is this going to work on a 991 7 speed?? Everyone knows how a 911 turns over-raspy, irregular until it 'settles in'. Will this happen every time you pull in/out of a stop. Supposdly you can disable the feature, but you would have to do this every time you started the car? I can't picture it starting and stopping silently like a 4 door luxury car.
Jim
Jim
Jim
Jim
Obviously Porsche is including this feature so that they can test the car while using it and eke out that last bit of mileage to up their corporate average. There are also some consumers who want features like this. If you don't like it, just leave it turned off.
I'm sure the basic operation will be the same with the manual although questions remain about whether it will only work in neutral, with the clutch disengaged, etc.
On a manual???
~A
~A
The computer will remember where auto start/stop was set when you last turned off the car, so if it was disabled at that time, you won't have to disable it the next time you start. That's how it works in my Cayenne S too. Also in the Cayenne, the system won't activate until the car is fully warmed up and even then will only shut down after you've been sitting for a few seconds. A quick stop at a stop sign, for example, won't cause the engine to shut down.
Yes. The computer remembering the setting at shutdown will be the same manual or auto. The ability to turn the system off will be identical on both.
From the Porsche web site here is a description:
The Auto Start Stop function is standard in the new 911 models. In the 911 equipped with manual transmission, the engine switches off automatically when you come to a stop, select neutral, and release the clutch pedal. In cars equipped with the optional Porsche Doppelkupplung (PDK) transmission, the engine switches off when you stop and leave your foot on the brake pedal. All audio and communication systems remain switched on and the climate control continues to maintain your selected temperature. The only differences you will notice are the silence at the rear and the fuel savings. As soon as you engage the clutch or release the brake, the engine will restart instantly and smoothly. The Auto Start Stop function may remain inactive under certain circumstances—for example, during extreme outside temperatures, if the battery charge is low, or if the Sport button is selected. It is also possible to deactivate the function manually using a separate button on the center console.
There are mods done to make this starting process much smoother than the typical cold start process. I'd be surprised if it is activated by default on the US cars - isn't it deactivated on the Panamera?
On the Cayenne the starter has been beefed up.
Yes, and on my '11 Cayenne S as well. Once I've deactivated AS/S with a button on the console it stays deactivated even when the car is shut down and restarted. The only way to reactivate it is to manually press the button again.
Found this feature to be far too noticeable on the Panamera (intrusive, even).
Can't imagine leaving it 'active' on a 911, stick or PDK.
Agree. I assume it helps Porsche meet their CAFE numbers but I almost never use it in the Cayenne, much less my 911 if it were so equipped.
I always thought most of the wear and tear was in the start up...wonder how that wear compares to the wear of and idling engine with good oil function...anyone know?
jb
jb
Jim
Jim
