Threaded shift knob conversion Numeric Shifter 991
Old Apr 6, 2026 | 10:59 AM
997lurker's Avatar
997lurker
Default Threaded shift **** conversion Numeric Shifter 991
Hey all!
Wanted to make a post as the parts arrive so I can share with everyone.
I originally made a threaded shift **** conversion for the 997 platform when I had one (https://rennlist.com/forums/997-foru...onversion.html) and thought, well why can't I do the same for the 991?
Originally I was using a threaded shift **** adapter off of my F80 M3 because it fit rather well, however, due to the large thread size, there is only a handful of shift ***** that work.
If you are looking for a simple shift ****, know that the Lathewerks shifter for BMW's works on 991 ( https://www.lathewerks.com/bmw-stain...hift-****.html)
Me being a OG Honda fan boy, gave me the idea to convert the semi threaded rod that comes on the Numeric Shifter, to a fully threaded M10x1.5 thread pitch so we can fit some cool *****. Hell might even throw on a Skunk2 shift **** like on my EG hatchback HAHA.
Anyways, TLDR. Making a threaded rod adapter that will screw directly into the Numeric Shifter, thus leaving a M10x1.5 Thread pitch rod so you can use any shift **** you'd like. I am awaiting my Circuit Hero Tear drop shift **** which I used on my S2000, 997 and now the 991.2
Will post pics as soon as it arrives!
Old Apr 13, 2026 | 10:57 AM
997lurker's Avatar
997lurker
Alright guys, as promised here are the photos of the unit installed in the car. Came out exactly how I wanted.
Parts needed:
(1) M12x1.75 to M10x1.5 threaded steel insert
(1) M10x1.5 x 100mm threaded rod
(1) M10x1.5 x 30mm
(1) M10x1.5 Shift **** of your choice
Optional M10x1.5 shift boot retainer to zip tie your shift boot
Installed ( don't mind the filth!)
Old Apr 13, 2026 | 01:08 PM
hsmith's Avatar
hsmith
this is so awesome. I too was trying to see how to fit a threaded shift **** on my 991... I wanted to get a nsx type r shift ****.
Thanks for sharing this info. Will this work the OEM shifter? Or only Numeric?
Old Apr 13, 2026 | 03:10 PM
997lurker's Avatar
997lurker
Unfortunately will only work on the Numeric shifter as it has threaded rod originally
Old Apr 13, 2026 | 07:52 PM
Joec500's Avatar
Joec500
ahhh so that smooth pipe looking part is essentially a coupler between the Numeric threaded portion and that threaded rod?
Old Apr 13, 2026 | 07:54 PM
Joec500's Avatar
Joec500
i assume something like this would work.
https://www.ebay.com/itm/22568225668...8TZ7TBN5TN686A
Old Apr 13, 2026 | 09:08 PM
997lurker's Avatar
997lurker
Correct, it’s just a threaded sleeve so that the threads aren’t exposed but at the same time adds more rigidity to the set up.
The size in the link is incorrect though, I had luck through Amazon and was even on prime
Old Apr 18, 2026 | 10:46 AM
997lurker's Avatar
997lurker
Getting this close to final form. Added a sheet on the inside of the shifter to leave the numeric exposed. Plan to wrap the whole shifter trim and sheet in Alcantara for a finished look
Old Apr 21, 2026 | 04:33 PM
997lurker's Avatar
997lurker
Couldn’t edit the above post with the revised photo but here is the shift boot delete wrapped in alcantara
Old Apr 21, 2026 | 07:26 PM
Joec500's Avatar
Joec500
I always felt the numeric shifter was too pretty hide. - Nice work
Old Apr 22, 2026 | 10:01 AM
997lurker's Avatar
997lurker
Right? Such a nice expensive piece to be hidden. This project turned out a lot better than I expected. I'm happy with the result and its always 100% reversible!
Old May 19, 2026 | 03:22 PM
hsmith's Avatar
hsmith
Wow that looks incredible. Nice job!
Old May 23, 2026 | 08:41 AM
Racer X 28's Avatar
Racer X 28
Shifter looks great! Quick question on a side note… I like that phone holder/charger. Is it magnetic and any issues with draining down the battery as it’s always plugged into the lighter plug?
