Intake filter or whole CAI?
Old Jun 2, 2025 | 06:40 PM
991.ju's Avatar
991.ju
Default Intake filter or whole CAI?
Some cars I've owned in the past the dyno results showed the oem CAI+Drop in filter got better results than aftermarket ones. For a 991.1 C2s does that still apply? or is it proven that a aftermarket one generates better performance?
Old Jun 3, 2025 | 04:07 PM
MikeL31's Avatar
MikeL31
i just swapped my filters for bmc. others here have installed the afe intake. afe claims +15 hp and +13 ft lbs tq. you can get the non carbon version for under a grand, try it pout and let us know.
Old Jun 3, 2025 | 04:14 PM
X-PH.COM - MIKE's Avatar
X-PH.COM - MIKE
Platinum Sponsor
if your concern is only performance and you dont care about the added sound, the BMC filters should be enough
Old Jun 3, 2025 | 04:25 PM
G.I.G.'s Avatar
G.I.G.
I just put a BMC filter in the factory intake in my 991.2 and called it a day. Admittedly, I haven't done any research on .2 air intakes but I'm a little dubious of the HP gain claims that are made. The factory intake is 'technically' a CAI based on the intake ports pulling air in from the rear grill inlet, and based on how cramped things are in the back of the turbo Carrera .2's, I can't imagine there is much room for improvement from the aftermarket. Curious to hear if anyone has had better results with an aftermarket CAI option.
Old Jun 3, 2025 | 05:18 PM
991.ju's Avatar
991.ju
ill take a look into those, i plan on ordering my exhaust from you as well, ill pm you when im ready.
Old Jun 3, 2025 | 08:44 PM
GermanCarFan1's Avatar
GermanCarFan1
Just buy the drop in filters like AFE and BMC, the entire "system" is negligible in gains. Anything else is a waste of money since nobody knows it's there but you.
Old Jun 4, 2025 | 10:22 AM
Viper1000's Avatar
Viper1000
Run stock air filters.....all the claims from aftermarket ones are bogus! I don't think you can find a dyno reading on YouTube that shows any increase in fact most show a decrease in power.......
Old Jun 4, 2025 | 10:38 AM
MingusDew's Avatar
MingusDew
Veteran: Army
The only fact about oiled filters, like BMC, is they need to be regularly re-oiled to actually function as a filter and stop dust particles. Which is fine, if you have easy access and are diligent with re-oiling, but that’s essentially no one with a 991 that requires the fascia and all the other stuff removed to even see the filter, let alone remove and re-oil said filter. It’s funny to me what people are willing to do to their engine for a questionable 10hp they won’t even feel the difference from.
Old Jun 4, 2025 | 11:01 AM
mhconley's Avatar
mhconley
BMC recommends cleaning and re-oiling their air filters every 20,000-25,000 kilometers (12,500-15,000 miles). I do mine every other year with my annual oil change / service (at about 7,500 miles).
Martin
Old Jun 4, 2025 | 12:24 PM
991.ju's Avatar
991.ju
for a intake filter i just like to get reuseable ones because one purchase that can last years and some reoiling seems more convenient
Martin
well. if its every 12k miles that would just mean i have to do it once a year which dosent seem too bad.
Old Jun 4, 2025 | 08:19 PM
MikeL31's Avatar
MikeL31
oem gt3rs air filters are bmc. you can buy them from porsche and they fit in almost all 991.1 but they're super marked up because its in a porsche box. if they were bogus, i dont see why porsche engineers would use it as an oem part.
https://www.suncoastparts.com/produc...1gt3rsafk.html
Old Jun 4, 2025 | 11:00 PM
MingusDew's Avatar
MingusDew
Veteran: Army
It’s not bad, if you don’t mind the labor involved to R&R the rear bumper fascia, other misc., just to get to a part that provides minimal benefit over a factory part that lasts 4x as long without servicing.
