Executive Leadership permitted me to have input on some recent bathroom renovations. I got to pick out colors and the general theme for the guest bathroom. I went with gulf blue, and some fun artwork for the walls. I did the electrical/lighting design. The room has the standard light switch and fan etc, but it also has low level lighting that turns on from a motion sensor. So if you need to use the facilities in the middle of the night and do not want to be woken up by a lot of light, the low light is enough to get the job done so to speak.
low level lighting with inner cabinet lighting going to light up the counters. Motion sensor eye that turns on the low level lighting.
That would make an awesome ceiling fan. Once while working at the McGregor range in NM doing tests with a Patriot battery, my friends and I walked around the range (yes, pretty dumb) and he found Nike missile fins, took them home and made a glass coffee table with them. Repurposed art is great.
