DIY: Program PSE at Home (ThinkDiag+)
#31
#33
#34
#35
#36
Thank you, I will be needing this in the coming weeks.
#37
figured it out. So I have the 991.2 steering wheel retrofit and I’m using the GPS X adapter for the drive mode **** to sync with the switch panel. I had to remove that adapter on my switch panel to assign the PSE on the panel using the thinkdiag. I can hear the valves open and close as I press the button so I think it’s working now. Going to drive around and see how much better it sounds from what I had. Most likely won’t be that much different so already planning to get a aftermarket solution.
#38
#39
nice! glad you figure it out! I don't have the PSE muffler and I am happy with the standard S muffler. It's already too loud for my wife. We can feel the vibration from inside the house and the door window is vibrating when the door is opened. It's making pops/crackles as well. I think i'll save the money that I was going to spend on an x-pipe.
1. The valves can stay open all the time as opposed to being controlled by computer previously. So I get much better exhaust gurgling when coming off the throttle
2. When driving with Wife and want a quiet ride I won't have valves being opened by computer either. Overall much better than stock.
#40
Same here. I'm happy with the sound of the -S center muffler. It's loud enough for me and biggest differences are.
#41
I bought and installed the new console switches, easy to do.
I bought the ThinkDiag+ and followed these programming instructions as listed in the first post.
However, there is no change in sound when I press the Sport Exhaust button. The PSE button does illuminate the red light when I press it or the Sport button.
The exhaust is significantly louder at cold start for about 30 seconds. The exhaust then goes back to quiet and the sound does not change with any button presses.
Do I have a problem with change over valves?
What should I try next?
3.Air Conditioning -> Code/Brush -> Brush/hidden Modified -> Coding -> Key Field Coding Value Keypad - - Sport Exhaust Flap Available = Yes (Default+No)
4. Air Conditioning -> Code/Brush -> Brush/hidden Modified -> BKE Key Field Assignment (Button 2, Right side = Sport Exhaust)
5. DME -> Code/Brush Hiding -> Brush/Hidden Modified -> Coding -> Coding Byte 1 -- Solenoid switchover valve for exhaust flaps = YES (Default=No)
My 991.1 S took all setting changes. I placed the Sport Exhaust button in the OEM location at Right 2.4. Air Conditioning -> Code/Brush -> Brush/hidden Modified -> BKE Key Field Assignment (Button 2, Right side = Sport Exhaust)
#42
#43
#44
#45
I've got a C4S w/o PSE and I was successfully able to code right button 2 to sports exhaust and this now works well, also in combo with Sports/Sports+ modes. I then coded right button 3 to Auto Start/Stop with the purchase/install of a new switch kit. The reason I put button 3 to Auto Start/Stop is this is the factory layout.
However, the Auto Start/Stop function no longer works. When Auto Start/Stop is on, the green circle in the dashboard comes on, and the engine doesn't stop (this is, of course, in Normal mode after car has warmed up). Pushing the Auto Start/Stop switch removes the green circle, so the light function seems fine, but not programming. I've driven around a bit to verify it wasn't temperature, etc.
The battery is fully charged and new.
To relocate Auto Start/Stop to right button 3, this was my approach:
Air Conditioning
Code/Brush Hiding
BKE Key Field Assignment (Button 3, right side = Start/Stop system, where default was not assigned)
Write Code
I also checked Coding Byte 1 under the DME for start/stop and it was enabled.
I backed out the programming to go back to default (switch 2 Auto Start/Stop with no manual control of exhaust valves). That is, default, but this still didn't get the Auto Start/Stop to work.
Any suggestions to get Auto Start/Stop to work again?
Air Conditioning
Code/Brush Hiding
Write Code
