spark plug removal with engine slightly warm or cold
Old 11-06-2023, 11:44 AM
DOUGLAP1
DOUGLAP1's Avatar
Default spark plug removal with engine slightly warm or cold
I'm getting ready to replace the spark plugs in my 991.1. The current plugs have only been in for about 20K miles, but need to replace based on time per Porsche guidelines. I've read a couple of nightmare stories about plug removal, and looking to minimize all risk.
Yes, I'm using the tools and procedures recommended by others on this forum, but I'm wondering if a slightly warm engine would be advantageous given the high thermal expansion coefficient of aluminum.
Anyone have any experience with this?
Thanks for any info.
Old 11-06-2023, 11:51 AM
CSK 911 C4S
CSK 911 C4S's Avatar
I don't think you would have trouble either way.
When I was doing those major services on my previous 991.1 I would always warm up for the oil change and then prep as the oil is draining for the spark plug replacement as the engine cools.
Just remember things get really warm back there quicker then you think so don't cook you hands or arms around the cats.
Sajan (11-06-2023)
Old 11-06-2023, 12:09 PM
asellus
asellus's Avatar
Received 2,117 Likes on 1,320 Posts
the reason you're supposed to do plugs on a cold engine is because aluminum loses a lot of strength very quickly with temperature when compared to steel.
personally I've never had an issue hot or cold, but I'm also a Risk Taker(tm), so YMMV.
Old 11-06-2023, 12:48 PM
duxsi
duxsi's Avatar
Unless you plan to have two singed stumps where your hands used to be, I'd let it cool down completely.
Those exhausts and shields retain a lot of heat for a long time.
Old 11-06-2023, 12:55 PM
Got Bearings?
Got Bearings?'s Avatar
As mentioned, you're supposed to do plugs on a cold engine otherwise the threads may come out with the plugs. I've done a few warm on Chevy V8s but I can remove a head in under an hour. I wouldn't think to do it on a 911... cost to fix is too high to wait a few hours or until the next day.
The following 2 users liked this post by Got Bearings?:
CSK 911 C4S (11-06-2023), lgusto (11-06-2023)
Old 11-06-2023, 01:57 PM
neanicu
neanicu's Avatar
Always cold unless you're doing Ford 3 valve,then smoking hot and use an impact gun.
Old 11-06-2023, 08:30 PM
DOUGLAP1
DOUGLAP1's Avatar
Thanks, that is what I was thinking, and targeting an engine temperature of only about 60 C (140 F) after the exhaust cools down. Looks like negligible effect on material strength, and should be less stress on threads anyway due to thermal expansion.
Old 11-06-2023, 09:28 PM
John D II
Basic Sponsor
John D II's Avatar
Always cold. Taking plugs out when hot can cause the threaded hole to contract too much as it cools.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
Old 11-06-2023, 11:45 PM
Flenn
Flenn's Avatar
You’re really overthinking it. Plugs on this car are a very easy diy job. Just have a swivel magnetic plug socket, some 3/8” extensions and a u joint. You’ll have no problems.
IXLR8 (11-08-2023)
Old 11-07-2023, 06:28 AM
duxsi
duxsi's Avatar
Next time you visit the dealership take a glance at how many technicians (they're not mechanics) actually bother to use a torque wrench.
Things are usually tightened and then they simply give the thing an extra quarter turn.
Old 11-08-2023, 03:56 PM
IWOA911
IWOA911's Avatar
Where you buy your magnetic plug socket? Brand? Thanks
Old 11-08-2023, 05:41 PM
Jack F
Jack F's Avatar
Warm/hot must be OK since lots of folks drive to the dealership to get this done and are out in a few hours.
Old 11-08-2023, 07:18 PM
SinkRate
SinkRate's Avatar
Scary, honestly.
I see stuff like that and think "If they're willing to cut a corner on something as simple and easy as applying correct torque to a fastener or spark plug, what else are they willing to cut corners on?" Just one more reason why so many of us are glad to have the tools and ability to continue to do the majority of the regular maintenance on these cars ourselves. Not only will you save some real money in the long term, but chances are the job will get done better than it otherwise would have at a dealer.
Old 11-09-2023, 08:58 AM
911T4ME
911T4ME's Avatar
I used this. Worked great for my 991.2 spark plug job.
BELEY 14mm 3/8 inch Magnetic Swivel Drive 12 Point Spark Plug Wobble Socket Fits BMW, Thin Wall and Cr-V Steel (14mm) https://a.co/d/adDx1Eh
Old 11-09-2023, 11:42 PM
RennListUser01
RennListUser01's Avatar
Originally Posted by SinkRate
Scary, honestly.
Remember, it's just a spark plug ... just cleaned and gapoed one in a pressure washer, today. Had a quick discussion with it ... it thought it was in a 1982 VW Rabbit. Yeah, no torque wrench. Said it didn't know what that was.
Quick Reply: spark plug removal with engine slightly warm or cold
