Recommend Dash Cam for 991.2
#31
I was considering Fitcamz for my 991. After reviewing comments on the Rennlist forums about Nav problems I decided to contact the company direct. I assumed with all the complaints they would have made internals modifications to correct this issue.
Comments from Fitcamx:
Hello,
Dash Cam Interference With Navigation systemsIt should be cable issue. This issue can be solved by replace the cable.
Best regards,Xyla
FITCAMX Support Team
My reply:
Your answer is not acceptable, if this is an issue you should upgrade all the units from the factory for the Porsche 991.Don't think I will purchase a product with a known defect. Your company's customer care / services need serious attention.
However, thanks for your prompt answer
Hello,
Best regards,Xyla
My reply:
#32
