Brand of wheel spacers
If you’re only looking for 5mm spacers all around, Suncoast Parts sells OEM Porsche spacers. https://www.suncoastparts.com/produc...HASSISWHEELACC
Depends on the size. As above, smaller ones you can get Porsche OEM. Larger ones I've used ECS without trouble, but you'll need extended lugs.
What ever you get, make sure they are hub centric. The Porsche ones are.
I got the Porsche 5mm spacers from sun coast all the way around and they are a great fit and perfect for what I need.
I got ECS Tuning (5mm front, 12mm rear) on recommendation from my indie. Added benefit was they came with the longer bolts, plus PCA discount at Pelican parts. Working well!
Rbeachva (11-25-2022)
The 12mm are on the front and the 7mm are on the back on a 991.2.
Those sizes make the widest part of the tire, Michelin PS4S, flush with the fender. Going with wider spacers will bring the thread edge closer to the fender’s edge.
It all depends on what you want to achieve. Going with wider spacers might throw more rocks on the outside of the fenders. fenders.
Rbeachva (11-26-2022)
