Let's say, God forbid, I have a random engine fire in my 991.2...I do have a 2 1/2 Lb Halotron, extinguisher. Where would I point it? 3 Openings on rear deck....
Not really a lot of options back there. Assuming you can even get the lid open if there really is a fire. I have to take periodic fire extinguisher training, and we're always taught to aim at the base of the flame and sweep back and forth. Works great on a flaming bucket of oily rags. Probably not so much on a 911 engine fire.
Back when I worked as a race track marshal, for SCCA, PCA, IMSA, Lemans, and F1, we trained with 20 lb dry chemical extinguishers. It was relatively easy to put out some training fires (mostly pits or large pans filled with diesel and gasoline), but anything with burning equipment got challenging. We we trained to use our minimum equipment to help get drivers out of the car--that is the primary mission. Once evacuated, cars are not that important.
The one time (IMSA) we tried to put out a burning, wrecked car (after the driver was removed) we emptied at least 4 or 5 dry chem bottles without doing much. Once the fire gets burning inside the car structure, it's hard to get the extinguishing material in there. The truck-mounted crew showed up in about 2 minutes and finally put out the fire with a big foam sprayer.
Car FE are there to help save the occupants from fire related deaths. Not likely you will put out a car fire with a 2 Lb FE by the time you see flames.
This makes the most sense!
My TTS was ordered with one and my mind immediately went to "Ugh..the first owner must have tracked it." But there's zero signs of track usage. Now I just have this red extinguisher under the seat which I assume after 8 years isn't even charged anymore? Lol!
the extinguisher is to either throw or swing at anyone who tries to help you put the fire out. In other words, once its burning, let it happen and call your insurance company and tell them where they can pick up their bonfire.
Thanks for your responses.....some of out local Clubs providing DE and Time Trial require them. In my former 993 track car, I had a complete system, with the 3 liter bottle in the Frunk, with nozzles in the engine compartment and the cabin. The fumes would probably have killed me had the bottle gone off. It had a "T" handle below the windshield, drivers side, and a handle inside the cabin, about $1,000 at the time. I am DE now, not going this route.
The present bottle and mount will have to do. Let's hope it is never needed...and agreed, put out fires, or attempt to do so, from the bottom up...this would mean taking a prone position on the deck at the rear of a burning car...as was said in an old Hollywood flick, "Let it burn!".
As for now, the present mounting will have to do...I will be flipped 180 degrees when I figure out hour to the the mount of the bead at the bottom of the bottle.
You're driving an insured car, not a one-off racecar that can't be replaced. Its for you or your passenger in case you're somehow on fire as you get out of the vehicle and wait for a firetruck.
