gts m800 turbo shaft seized
My driver side m800 has seized last mount,called Tial sended the turbo then they let me know the diagnostic and they repair it at no cost !so putted back my stock turbo . Mean time i enjoy my stock turbo cuz they make good torque down low but they die so fast in upper rpm and with the same tune of my m800 i make the same power as a stock gts (1/4mile 11.3@124mph) but to compare m800 make so much more power up top its night and day ...cant wait putting back my m800 soon
Just want to say that Tial have outstanding service and they dont bother ...
Any idea why the shaft seized? An oiling problem?
Are you running a pro tune on your GTS turbos?
You were making some crazy power with the M800 turbos.
Btw im on base turbo now not gts im running the same protune on my base as my m800
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/900x2000/screenshot_20220723_080348_23cd1946c3fd10b77095ba7ca8581ee9bff075a8.jpg)
1/4 mile base carrera turbo with protune
You are running your tune that you use on the m800 on your base turbos?
I'd actually lean towards turbo over speed leading to the thrust bearing failure. When you over speed the turbo, turbine pressure ratio goes way higher than compressor pressure ratio, so you get a ton of thrust load. Combine that with hot oil with low viscosity and you get metal on metal contact at your thrust bearing accelerating wear. And when it wears out, the whole shaft starts moving around more until it rubs and eventually seizes.
thesaintusa (08-27-2022)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/900x2000/screenshot_20220827_150351_email_cad838eeddf1c3d9760c9e544ccc6ee5b0e5191c.jpg)
thesaintusa (08-28-2022)
This what TIAL say: The thrust bearing is clamped down when the 6 bolts that fasten the compressor hsg down are tightened. If these are not properly tightened or 1 or 2 are left loose or under torqued the thrust bearing will lose oil pressure and damage the thrust bearing as seen in the picture below
I linked this video to start a bit before when the person installs the thrust bearing. The thrust bearing is located in rotation by a dowel pin. In the picture sent by TiAl, it looks like two dowel pins are used on the circumference of the thrust bearing. The thrust bearing is ultimately held in place by the seal plate which is locked into place by a snap ring. This is standard Borg Warner design. Garrett does it a little differently in their journal bearing CHRAs.
vanlieremead (09-04-2022)
While I applaud their customer service for taking care of you, what they said about the thrust bearing being clamped down when the 6 bolts holding the compressor housing on is COMPLETLY WRONG!!!! They should have an engineer or manufacturing technician explain it, not whoever answered your message.
https://youtu.be/nbfRNgo9mo4?t=64
Thx , @spdracerut im not a scientiste in turbo stuff so your final conclusion is overspinning turbo's?if so what can cause this issue?
Or an oiling issue, i.e. perhaps you didn't have an overspeed situation.
