Oil level above maximum possible to drive on
No...each line on that meter is very little amount of oil. If you add 1/4 - 1/3 quart it will move quite a bit.
300 mil or about 1/3 quart (as Joe noted) will move the electronic gauge one segment.
I keep my oil level on the 3rd or 4th segment, never at max.
Learn to change the oil yourself. This is the easiest car that I have own regarding oil changes.
better to overfill by a little than to underfill.
give it a few days and it'll settle.
Many times the amount sitting in the canister is all that is needed to stop the warning, and this is a common DIY trick to resolve it on any car assuming it hasn't been massively overfilled. Ive only had to deal with once so far personally, and I had to dump the canister, reinstall and start the car for a few seconds to fill it up again and then dump a second time. Still better than draining it all out and starting over IMO.
Before when my oil changes ever free from the dealer and I had them do it. They overfilled the engine oil one time. I picked up the car and right away when I drove it and it went past 3k rpm the engine/car would start shaking like vibrating hard. I took it back right away and they took out some oil since it was filled up too much. The car afterwards drove just fine. I do my oil changes now.
Crush washers are just a piece of aluminum. Why would you really need to put a new one on? I’d expect the soft, thin aluminum just deforms/conforms as you tighten the drain plug so wouldn’t it just keep deforming/conforming as long as it still had some thickness?
But does it? It’s just a flat piece of aluminum. They aren’t shaped with a crushable geometry like spark plug washers. Just wonder if the concern is work hardening potentially causing the washer to crack. But the tiny amount a crush washer is deformed likely wouldn’t make that a factor.
If its massively overfilled then you need to fully drain. Porsche are notorious for their slow drain. My Indy always fills .5 quart less and then tops up as needed. This is a pain with the electronic dip stick. That's why the labor is longer than you would suspect. Either educate who changed your oil or use someone who regularly does Porsches. I do NOT recommend trying to drain a small amount from the drain plug, especially if the oil is hot. I've seen a mechanic get a pretty severe burn doing that with hot engine oil. If it persists after a day or two of driving, dropping the oil filter canister is probably the best way. As already stated the drain plug does not technically have a crush washer. It is an aluminum or copper alloy that I suspect is softer than the plug and the pan. Do not over torque the drain plug. After inspection I regularly reuse.
I had a 987.2 massively overfilled by two quarters. I had supplied the right number of quarters, so makes me wonder if he used bulk and not my oil. Went back and had them drain 1 qt. Still got the over fill message. The Indy refused to further drain the car. Went to Jiffy Lube with a clean graduated container and had them drain all the oil. It was still a quart over. Took a picture of the container showing the amount and refilled the proper amount. I went back to the Indy and talked to the owner who refused to drain the oil. It was not a two way conversation. Showed him the picture. Told him both he and his employees were unprofessional and incompetent. Spread the word for others not to use. Later talked to the shop manager who apologized, but in so many words agreed with me. He could not explain were the extra two quarts came from
Now the car is telling me there is too little oil and it's at the minimum even though they put the same amount back in.
We're going to change the oil sensor Monday -- keep you posted!
Like I said.
There is nothing to worry about.
The oil sensor is very sensitive and finicky, give it a few days after you've changed oil to allow it to settle down.
The more you try to "fix" it the more it's going to give you false readings.
Just leave it alone.
So ended up changing the oil sensor which made the problem go away.
Now I have a new problem. When I changed the oil they did my spark plugs and air filters.
Started the car today and noticed a weird smell. Then when I took it out again later it smelt like gas on the driver's side.
Any ideas?
Thanks!
Any ideas?
Thanks!
