Hey ,
my Door trim panel box cover broke as you can see in the picture , can i buy this part , does anyone knows whats the part number of it ?
i dont want to buy the whole door trim panel !!
I don't think it's available as a separate part, unfortunately. Your best bet might be to find a driver door panel used on ebay that you can steal parts from, and then just sell what remains of the donor panel.
unfortunatly the cheapest one cost 1299 $ , the only thing that i want is the door pocket !!!
JB WELD or WD40 fix almost everything or duct tape it shut w gorilla black tape,,do U really use that space
i dont use it at all , but its opened all the time , does not look good you know , right now i but a black tape on it but this is not along term solution !!
I just installed sound deadening and if you decide to remove the door panel for a repair, they are easy and quick to remove. The storage pocket has spring loaded hinges that look to be a challenge to remove. I have heard of some members having success making repairs on the plastic making a slurry with donor ABS scraps and acetone. And as mentioned above the JB Weld should also work.
Jim Spring loaded hinges
