Help with identification of wire
So I’ve my 2014 991.1 S for about a year. Today while washing I noticed a wire going across the passenger side radiator vents, inside the vents between the vents and radiator. It runs on the passenger side only. Is this an after market wire for something, or factory and maybe just recently has fallen to where it’s visible?
Also, when I bought the car it had these wires in the frunk. My guess is audio equipment? The ends are cut on one end and the female plugs are on the other end. Anyone know what this was used for?
Do you think the wire going across the radiator area is after market, or is that a factory wire?
The cable ends you pictured are 6-pin mini DIN -- think PS/2 keyboards and mice, the purple and green connectors, before USB took over.
A laser jammer does seem likely -- those use multi-pin DIN connectors frequently for the external units. Nothing in audio uses those.
Those look like escort
Wires to me, i have put in a bunch of units over the years. Just leave they dont hurt anything as no power.
911Raider (07-24-2022)
Laser jammer or Radar detector wiring. Definitely not OEM wiring. I don't like extra wires hanging around, I would remove, but not a necessity.
Escort system:
Escort system:
