Centerlock wheel swap...surprises (4)
Not even close, just pick up a good 1/2 drive with a breaker bar combo. About 200.00 for the wrench set. It's not that hard to hit the 440ft lbs with the size of the breaker bar. And never, ever use a torque wrench to break them down, always use the bar!. First time was intimidating, but after that it's a cake walk. Only big worry is getting a flat and not having the tool if you have to hit a tire shop.
The "Central Lock ..." linl below, contains all the information one will need when changing and maintaining center locks. A most gtacious RENNLISTER posted this recently. It has numerous AaaaHaaa moments contained therein.
Curious Cat (03-15-2023)
- They are forged aluminum,
- They are nearly impossible to steal, need at least 440 lb-ft of torque to break them loose. The front wheels require a helper to hold the steering wheel steady addressing the torque put on them to break them loose. This forces the thief to break in the car possibly/hopefully setting off alarms.
- Many feel that bring an exotic look to the GTS cars
- On my 991.2 GTS, it comes with 9" front and 12" wide wheels, 1/2 wider than the 991.2 Carrera S. Cant's speculate on the 997.2 GTS and the 991.1 GTS.
Or spend $5K on a Hytorc tool and fix the problems with centerlocks.
Martin S. (03-16-2023)
Those who buy the 997.2 GTS, the 991.1 GTS and 991.2 GTS cars, most of these cars were originally ordered with center locks. Those of us are/who are lucky enough to buy these cars (Used), will inherit center locks, like it or not. Folks who bought new could have spec'd 5 lugs. There features of the 991.2 center locks that many appreciate, or use these features to rationalize their displeasure with center locks:
for me I know it holds the torque better (proven, look it up). less breaking\snapping of the bolts, nice looks..Once you do it a. few times its not that hard (yea you could need 2 people) ..BTW 5 lugs...Its not like you carry a spare tire for the tire in the frunk. Anyways most tire stores that have n rated tires are typically capable of handling center lock (not always, but most of the time)..I am very picky of who changes my tires on the rims anyways......
but, for me that why I bought a GTS is for all those little nuances..and if I were looking to buy another GTS I would go back to center lock....
Martin S. (03-17-2023)
For those following/reading this post, read "ihbond" post above (Glance my my post too if you must.). At the end of "ihbond" post, which is a response to my post, you will know all you will ever want, or need to know about center locks. At that point you can unsubscribe from the thread.
In my case, I went from "I gotta get rid of these", and have decelerated to my present position of "Ho Hum". These wheels are just wheels, and I will need to remove, one or all, rarely. When it is necessary, I have the tools and have accumulated the knowledge to do so.
I feel that now is the time to inscribe to this thread and dream about future mods such as headers, possibly sport cats, diverter vales, etc.
