991.2 cup holder in center console
Has anyone installed this cup holder (Kaizen lighting) for the 991.2? It goes in the center console in the position that the 992 cup holder is. Looks intriguing but you have to take apart the center console to install it. The link is below.
https://flat6motorsports.com/product...39606693298260
indeed
As i new 911 recipient and having used the factory cup holders a bit, i just ordered this, I don't mind the factory cup holders not the best but iv'e had to use way worse, i'm hoping i will enjoy this a bit more as driving with half the dash hanging out is at best tolerable.
This seems like a good solution when compared with the factory cup holders. I'm just a little hesitant to take the console apart and wanted to see if it was worth the hassle before i pull the trigger on this.
Wow I can’t believe I haven’t seen this before. Pricey but if it blends with the factory plastic, no brainer. Ordered.
As long as you have plastic interior pry tools, the console is super easy to take apart and put back together.
991_T (03-31-2022)
This looks like it's a quick install without taking the console apart.
Package Includes: 1x Cup holder. Satin Black (Matching black to center console) Plug and play. 5 min install time.
Kaizen does have an install video. It's literally pulling the chrome surround from off. Pull the shifter aurround up, pull the small trim off, pull the button trim off. That piece ended up being hardest to pull off, then the little bin slides out. You slide in the soda holder, and pop all pieces back in reverse order. No tools needed except perhaps a plastic pry tool. Here are pics of the "low profile" version that holds soda, but i use to hold keys and coins.
jbendaou (03-31-2022)
There are a few versions. The low profile that I got and posted above. A higher lip version that should be able to hold larger drinks more sturdy and a higher lip version with a slit to hold cell phones.
jbendaou (04-01-2022)
it's a perfect OEM fit, but color is slightly more matte than the slightly shiny black trim. You can see the difference in my photo.
flsupraguy (04-01-2022)
