5lbs antigravity battery vs oem 58lbs
#31
Having the car coded for a lithium battery definitely changes the alternator charging profile. I bought the 30ah antigravity battery in 2018, and after a few months began getting "electrical gremlins" - rws fault, ok to drive, etc. The car would always be at 15.0-15.1 volts charging, even after coming off the cetek lithium charger, and fully charged.
Antigravity took the battery back, and replaced it with the 40ah version (highly recommended). Since I was still always getting the 15.0v charging from the car, I had my indy program the car to lithium. Now the car slowly ramps the voltage up, from 14.3 to about 14.7, then back to 14.3 when the battery is fully charged. I haven't cetek charged the battery in 2yrs, driving the car for 20 min once a week is enough to keep it fully charged.
#32
I installed the 60 AH AntiGravity battery over two years ago not and it has been flawless. I normally use a LI specific battery maintainer when parked in the garage and during the 6 months of 'winter' storage in this climate. Took a 5 K miles trip last Summer and no problems what so ever. Great new technology and , while expensive, I consider it on par with the other technology of our German machines!
#33
No issues with my AH40. Very happy with the weight savings over stock and I have tons of CCA’s, never an issue.
F1SML8R (03-27-2022)
Fullyield (04-01-2022)
#35
#36
Your logic makes sense, but in reality, it may be slightly off. Reason I say that is I bought a 2015 M3 which came with a Lithium battery. Sat in the showroom mistakenly plugged into a regular showroom charger for a lead acid battery. Day after delivery, battery was dead...as in completely dead, ruined, kaput. Dealership paid for a new battery. Incorrect chargers are well known to kill Lithium batteries, so for the $95 it costs for a proper Lithium battery charger model (Ctek), I wouldn't F around with a $1,000 battery just to save a few bucks. YMMV.
That said, the BMS in the AG battery is designed to not require such changes to your vehicle, and in fact protects itself from over and under charging, per AG themselves who openly state they have tested this on many vehicles and basically never saw over 15v, which means that your alternator and your old 1997 Schumacher battery charger should be A-OK to charge. That said, they also go on to say that AGMs shouldn't be charged over 15v which is objectively incorrect, and that alternators "sense air temperature" to raise voltages, so what's the real truth here?
#37
Correct. The AG battery is around $750. To put it into perspective.. Porsche is charging $11,000 for a lightweight package that shaves 60lbs off of the cars weight. You can shave 40lbs off by just changing the battery. Want to shave another 25lbs?... change the wheels to lightweight. Want to shave another 25lbs? Change the exhaust to titanium. Almost 100lbs saved and still less than Porsche charges...
I went with the highest amp AG battery because I had an aftermarket stereo, custom installed radar and front and rear dash cams, so my parasitic draw even when the car was parked in my garage was high. With the AG battery I had no errors or faults, no need to recode anything and the battery cranks like a MF...
pride355 (03-27-2022)
#38
#39
#40
You’ve got to do what works. electricity can be bizarre and I claim no mastery over it. I’m doing something different than most. I only top charge and disconnect. All lithium equipped vehicles just will not take any charge regardless of the charger used. It’s more of a manual operation for me monitoring input voltage over time and voltage cutoff either by me manually or automatic by the charger. After all you are only adding dc at a certain amp input. All chargers simply add virtually nothing in my situations before reaching max volts. All lithium equipped just remain high volts. So I’m in a different camp from those leaving chargers hooked up for extended periods. Chris at anti-gravity said there was no need to code for lithium however next maintenance I’ll have them do it anyway.
asellus (03-26-2022)
#42
My experience was more a case of the battery BMS and car BMS not working well together. The car itself was over-charging the battery causing a huge spike in voltage which caused the battery BMS to cut the voltage dramatically for a second to compensate, but that was triggering the RAS system control module fault. Dealership was making claims that the battery voltage spike could permanently damage the RAS control module, so a quick assessment of the costs of covering a new one (likely not covered by warranty), made me realize it was probably better to just send the AG back and try again in the future. With that said, I will look into the re-coding of the car to accept a Lithium battery.
#43
#44
To each their own. I'm nowhere near a good enough (or aggressive enough) driver to notice 40 pounds missing from the cowl of my car, and it's just not worth the headache of "ah crap, did I plug in my car" every four days. I didn't buy a Nissan Leaf for a reason, damnit!
