Lightweight Flywheel MT
Old 07-31-2024, 05:35 PM
  #46
AdamSanta85
AdamSanta85's Avatar
Received 1,245 Likes on 730 Posts
Originally Posted by IRunalot
Absolutely will report back which I buy and how it works. Think I'll go with metallic as its more robust.
The stock clutch can handle up to almost 600… good choice with the higher capacity.
IRunalot (07-31-2024)
Old 08-29-2024, 07:46 PM
  #47
Joec500
Joec500's Avatar
Received 1,025 Likes on 610 Posts
Well... My pressure Plate has started to fail so I just ordered a LWFW, will keep ya'll posted
IRunalot (08-29-2024)
Old 08-29-2024, 07:47 PM
  #48
IRunalot
IRunalot's Avatar
which one did you get?
Old 08-29-2024, 10:47 PM
  #49
Joec500
Joec500's Avatar
I bought the standard Aasco One that works with the OEM style pressure plate and flywheel.
They have a sport version that works with the 996 pressure plate as well, but I didnt didn't see a huge advantage for the $1,000 delta.
Old 08-30-2024, 12:54 AM
  #50
MingusDew
MingusDew's Avatar
Received 1,233 Likes on 620 Posts
Have you considered installing a mechanical LSD while you’re in there? Even swapping to a GT3 unit has notable effect.
IRunalot (08-30-2024)
Old 08-30-2024, 06:12 AM
  #51
malahhaor
malahhaor's Avatar
opening up a transmission and installing new flywheel and clutch are a tad different. I wouldn't call it while you're in there....
but it does sound interesting 🤔 😏 👀
What kits would fit? Do you know? I have 991.1 C2
Old 08-30-2024, 07:39 AM
  #52
IRunalot
IRunalot's Avatar
Wait there is a mechanical LSD for these cars?! Please show me where.. I thought the aftermarket diffs were only for the PDK..
My Clutch will be end of the year and a REAL LSD would be nice.
Old 08-30-2024, 11:18 AM
  #53
MingusDew
MingusDew's Avatar
Well there is at least the GT3 one, which is what is also used in the Carrera T. I’m not sure about aftermarket, but surely someone makes something. Right?
Old 08-30-2024, 12:39 PM
  #54
Joec500
Joec500's Avatar
not sure the difference or even compatibility of the gt3 mechanical diff on standard Carrera. But I do know Manual 991’s have a mechanical diff and the pdk has a “smart” diff to better integrate with the auto trans
Quick Reply: Lightweight Flywheel MT
