Fuse keeps blowing when I use my remote
So I keep blowing fuse B4 (left footwell). And it seems to be when I use the remote when I lock/unlock the car. Not sure yet whether it's both lock/unlock or just one.
It's dangerous because when the fise blows I lose amongst other things RR brake light. RR positioning led light. RR reverse light. Middle brake light. FR drl.
This started yesterday afterr it rained. I got error codes about my lights. And self diagnoses this as the fuse given all the weird lights that were down.
Check to make sure your drains are clear under the battery cover.
Have any wet carpets?
Is the car new to you?
No accident?
Could there be some wire chafing in the doors causing a short?
If you replace the fuse to get everything working ...... and you don't lock and unlock your doors does the fuse still blow?
No accident?
I don't think it was asked but have you run a computer diagnostic on your car?
Go through all the modules and let the scanner do a test and see what pops up.
If there's a sensor that has failed I would think it would show up. Might help narrow down your issue.
991Targa4S (01-20-2022)
