A different take on a rear seat delete
#31
Yes, the seller I purchased it from stated its a 991.2 GT2RS/GT3RS Alcantara CXX rear stray.
Same part number as the one posted here.
This is a very interesting piece to me because I have not really ever seen this installed on a car aside from this thread. All the photos I see of the .2 RS interiors have complete "rear seat delete" panel with carpeting. This piece lays on top of the original carpeting and bolts in the same center screw the lower seat pad is secured too.
Anyhow I got it installed. The Alcantara is a shade off from the center arm rest on mine at least. Not sure, perhaps a manufacturer variation since I also have dash end covers in alcantara which don't fully match what came inside the rest of the car.
100% better than the exposed metal and center bolt screw look!
OP, Thanks for the information
F1SML8R (12-28-2022)
buddalun (12-28-2022)
F1SML8R (12-29-2022)
jimjoe997 (01-31-2023)
#38
I must be doing something wrong. Still can't get it to fit. Any suggestions?
I see the tabs where the trim piece is supposed to go, but I can't push it that far forward because it hits the armrest.
It's as if my armrest is too long (?)
#40
Open the center console, then fit the piece. There are two tabs (you can see one in your pic) the tabs slide into the receptacles as seen on the opposite side of the console. With the armrest up it should slide forward and down.
jimjoe997 (02-03-2023)
#43
I appreciate the input from everyone, but I just can't get it to work. Please see the video.
Both tabs were locked in, and the bolt was centered. When the armrest swings back, the hinge immediately hits the trim piece.
I think I will try something more drastic and ill advised. Can't return the trim anyway.
