ABS brake bleed/flush with PIWIS, iCarsoft or similar
Old 07-31-2021, 04:08 PM
Zylinderkopfdichtung
Zylinderkopfdichtung's Avatar
Default ABS brake bleed/flush with PIWIS, iCarsoft or similar
Does anyone have experience doing an ABS brake bleed using an OBDII tool like an iCarsoft or Porsche PIWIS?
I added front stainless brake lines yesterday and the pedal is slightly soft. Some have recommended doing an ABS bleed which forces the system to activate, thus purging any air trapped in that part of the circuit.
I’ve watched a few YouTube videos on other cars. The procedure seems to be all over the place.
I intend to use a pressure bleeder on the master cylinder and flush all of the lines. I can then use the iCarsoft to activate ABS bleeding as well, but unsure if I do it before the regular bleed? After? Do I need to use the brake pedal as well?
Old 08-01-2021, 12:22 PM
Rapter
Rapter's Avatar
I am looking for a similar solution for my 991.2 car
Old 08-01-2021, 01:35 PM
I’m going to try using the iCarsoft V3.0 and its instructions and bleed order.
The iCarsoft mentions having a 2 bar pressure on the fluid reservoir. That’s 29 psi which seems like a lot for my Schwaben bleeder, however.
I’ll report back today.
Old 08-01-2021, 06:09 PM
I just finished the iCarsoft ABS bleed. Unlike the conventional RR, LR, RF, LF sequence it had me go LR, LF, RF, RR. The ABS activates as you pump the pedal, which I did about 6-8 times per wheel. I pumped my Schwaben power bleeder to ~25psi but it started to leak. I then left it at 15psi which seemed to work just fine.
It’d be a much easier process with 2 people, even with a power bleeder.
Old 08-01-2021, 06:42 PM
Jack F
Jack F's Avatar
So this procedure is similar to brake fluid replacement with a pressurized u it like the Motive bleeder but because of the icarsoft 3.0 unit it gets the fluid out of the abs system too? How much fluid did you go through? Thanks
Old 08-01-2021, 07:12 PM
worf928
worf928's Avatar
Received 1,623 Likes on 1,060 Posts
The first time, immediately after the line change, what did you use to flush the system?
And, did it work? Is the pedal still soft or not?
Old 08-01-2021, 08:53 PM
Pressure bleeder, but I did not do a complete flush front and back—just the fronts. I suspect not doing a full system flush was the reason for the sponginess.
Rock solid. I did follow up the iCarsoft LR, LF, RF, RR ABS routine with a standard RR, LR, FR, FL for good measure. Not sure it made a difference.
Old 08-01-2021, 09:42 PM
Not sure exactly how much fluid it went through as I pouring fresh but bled fluid back into the pressure bleeder. I had two 1L cans of Endless and used both, but mostly out of an abundance of caution as I’d previously pushed air into the system cuz I’m overconfident in my wrenching abilities
Old 08-02-2021, 10:07 AM
Rapter
Rapter's Avatar
can you post what model icarsoft v3.0 you used?
is your brake pedal rock solid?
Old 08-02-2021, 10:59 AM
This is the model I got:
Amazon Amazon
Pedal is rock solid. Modulation of braking force is exceptionally easy as there's such little deflection (after the first ~2").
Old 08-03-2021, 12:33 PM
CSK 911 C4S
CSK 911 C4S's Avatar
Thanks for sharing. I need to see if my iCarSoft Pro has this function.
Old 08-03-2021, 12:57 PM
Try upgrading the iCarsoft software first. There’s been two updates to the 991.2 software since I got the unit about a month ago.
CSK 911 C4S (08-03-2021)
Old 10-26-2021, 08:18 PM
Archippus
Archippus's Avatar
Speaking of upgrading the iCarsoft software, is it compatible with Apple products or do you have to use a Windows PC?
Old 10-27-2021, 12:13 AM
asellus
asellus's Avatar
Received 2,091 Likes on 1,299 Posts
According to their FAQ:
Q: Can I update the scanner on my MAC?
A: Sorry, currently our scanners can only support updates on Windows OS such as Windows XP, Windows 7, Windows 8 and Windows 10.
Old 10-27-2021, 09:40 AM
Archippus
Archippus's Avatar
Thank you asellus. I'm having trouble finding a good scanner that can be updated on a Mac. I could try to fire up our old PC but it is old and not that reliable.
Quick Reply: ABS brake bleed/flush with PIWIS, iCarsoft or similar
