@Got_Corners? Looks great! This wing has been on my short list. Would love to see that wing fully deployed. Would you happen to have any pics of it deployed and/or from other angles.
@Tier1Terrier Here is the Moshammer tail on my 991.1.
Half deployed
Dang it, @MagicalCanoe . That looks just PERFECT!!! Thank you for sharing those images. Couple of questions...
- I see it deployed at two different angles/heights. Is the highest deployment shown at full standard deployment? Or is that the deployment height as when the vehicle sunroof is opened? I cannot figure out how to get mine to deploy to the 'sunroof deployment height' when the vehicle is parked and wasn't sure if there was a trick to that.
- Also I see you have some other nice aero pieces on your narrow bodied 911 (mine is also a NB 991.2 C2S). Care to share which side skirts and front spoiler your using? They look great!!!
Haha, thanks! It was a journey and painful one (in regards to the sideskirts and front lip).
Others can correct me if I'm wrong, but there is only one deployment height from the factory, full deployment. You can adjust the height when the car is stationary (just hold the spoiler button and let go at desired height). When the car starts moving, it will close back down or fully deploy. My side and front view pics are at full deployment.
Sideskirts: Design 911. Bought it from a Rennlist member actually. I had 2 expensive body shops try to install it. First body shop used wood screws and one side had a large gap and double tape failed near the front of the side skirt. 2nd body shop tried to fix it and made more unnecessary holes and the the double tape failed worse. It would have eventually been road debris, so I decided to fix it myself. Aligned new holes with the factory mounting points (you would think that would be common sense). I used adhesion promoter correctly and allowed it to cure properly. I then finished it off with bathroom sealant so there's no visible gaps.
Fit: 7 out of 10.
Front spoiler: CMST Tuning. All carbon fiber, but I color matched it except for the center. I left that exposed CF. Took 6 months to get and it came damaged. Luckily the damage was where I was going to paint anyway.
Fit: 8 out of 10. There's still some gaps that I need to re-adjust. Good body shops are hard to find, simple things may be better left to yourself.
Rear diffuser: Moshammer. Painted mineral gray metallic.
Fit: 9 out of 10
Rear spoiler: Moshammer.
Fit: 8 out of 10. The mounting tabs were way too thick. I had to dremel them down to fit the stock mounting clips. I sanded some parts to get it to sit flush. Came out nicely with all the prep work. I had the body shop remove the logo. Looks like it's a better fit with a 991.2
Buy a 2017 c2 base pdk pse Bose with low millage and did the gts turbo swap with a stage 3 arp tune now the car woke up ! Love the rush in first and second gear !not à cheap mod but worth it
I'd love to see a build thread on your car! Looks really great. What side skirts do you have on the car? And what model is your 991.1?
Thanks. If you search my threads i have somewhat of a 991 intro thread. It's not an actual build thread but i shared some info of the process. The sideskirts are OEM 991.2 GT2/GT3RS
[QUOTE=MagicalCanoe;17569761]@Tier1Terrier Here is the Moshammer tail on my 991.1.
Good day
I love the rear wing, it is just the right fit. I was wondering if that's a aftermarket add on and if so who makes it if you can share the link. I have a 2013 991 with the standard wing, and would love to change it up. Nto sure if it's a big job to do the upgrade.
Good day
Fatola
From my post above:
Rear spoiler: Moshammer. Fit: 8 out of 10. The mounting tabs were way too thick. I had to dremel them down to fit the stock mounting clips. I sanded some parts to get it to sit flush. Came out nicely with all the prep work. I had the body shop remove the logo. Looks like it's a better fit with a 991.2
