Blue tooth streaming music problem
I recently updated my iPhone XS to IOS 14.5.1 and can no longer receive music in my 2013 991 via Bluetooth. The phone works to the PCM and the USB connection work fine. Does anyone have a suggestion? It worked perfectly before the update.
have you tried removing the pairing and setting it up again with the pcm?
Thanks for the suggestion. I tried it but that did not do the trick. I have since turned the car off for a few hours, restarted the phone and checked it after your post but no luck. I then pressed "Deactivate Device" and then a few minutes later pressed "Activate Device" and that did it. My entire PCM system is getting swirly as the years progress. Last year the whole system went down, I had to do a complete reset and reprogram it with all my preferences. What a pain!
Do you have the latest PCM Software installed in you 991?
Version 4.67 is the latest version on 991.1
What 991 do you own? What version is installed?
You can search this forum for a link to the DVD to upgrade yourself or let your dealer do it for $s.
That is also an interesting thread on the subject:
https://rennlist.com/forums/audio-an...-to-ssd-4.html
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I have a 2013, 991 with PCM version 4.4 installed. Although it worked yesterday, it does not again today. I tried uninstalling the phone and then reinstalling it and nothing. Where do I find a DVD to upgrade the system?
There's a pretty big thread if you do a quick search. A quick glance shows that other people have similar issues.
