Patchable tire?
Old 04-15-2021, 05:00 PM
Jay2Lab
Jay2Lab's Avatar
Default Patchable tire?
I was planning to go for a drive this afternoon but my tire pressure was low in my front driver's side tire. Found a screw in it and it's so close to the sidewall. I'm about to schedule service for the car and figured I'll have them repair or replace the front tire. I only have about 4k miles on the tire but I'm willing to replace if necessary. Just hoping to hear other opinions on whether this might be patchable before I give the green light to replace it since I was hoping to get at least one more season out of it.
Thanks,
J
Old 04-15-2021, 05:08 PM
asellus
asellus's Avatar
Received 2,117 Likes on 1,320 Posts
that'll get marked for replacement by any shop, they won't take the perceived liability plugging a tire with a hole that close to the shoulder..
personally, I'd plug it and call it more than good enough for street duty. it's on the outside shoulder so you'll very quickly notice sidewall bulges if it's actually a problem.
Old 04-15-2021, 05:11 PM
GKGEIGER
GKGEIGER's Avatar
I have had good luck with patch plugs. I would be concerned about how close to the sidewall it is. It might be fine to plug. I just got a call from my dealer that I have a nail in one of my rear tires. Left here yesterday on a flat bed. Getting a new water pump. Wasn't leaking at that time. I'm at 20k miles and second set of rears. I will probably go with four new tire.
Old 04-15-2021, 05:27 PM
911.'s Avatar
If its a daily, I would patch it and run it till its ready to be replaced. If you do any serious track time or lots of spirited driving I would just replace the tire.
Old 04-15-2021, 06:02 PM
ICU991812
ICU991812's Avatar
I look at tires and brakes as the two most important parts of the car to keep top notch and well maintained. I personally would not feel safe driving with a plug or patch that close to the sidewall. Even if you were to drive only 55 or 65 mph on the highway, do you really want to risk personal, vehicle, and worse failure? A new tire is $350-370, even times 2 to even the pair, $800. Is it really worth saving the $800?
Old 04-15-2021, 06:13 PM
BSO
BSO's Avatar
I've had the unfortunate luck of losing three tires to nails. The dealers won't touch them and Discount Tires refused to repair as well, even though I was a repeat customer. Discount's advise was to go to a "mom and pop shop" for the fix.
This par for the course nowadays, nobody wants to repair, just replace.
So I've bitten the bullet and replaced them at the dealer but also benefited from no damage to the rims in the process.
Yours looks too close to the edge to repair, too much flex in the area.
I'd rather err on the side of caution and go for new. Your tire looks like it had a lot of life left, which is a shame, but such is life.
Old 04-15-2021, 06:19 PM
justbob
justbob's Avatar
Smile
Back it out or unscrew it. If it didn't go to far in, you may be to the good. If it seeps air (us soapy water and look for bubbles) patch it from the inside.
Old 04-15-2021, 07:15 PM
CSK 911 C4S
CSK 911 C4S's Avatar
Unless you are a DIY'er with a plug kit no one is going to patch it for you unfortunately.
Old 04-15-2021, 07:28 PM
Southbranch
Southbranch's Avatar
No responsible tire shop or dealer would attempt to repair a puncture that far onto the shoulder of the tread.
Al.Fresco (04-15-2021)
Old 04-15-2021, 07:34 PM
Joec500
Joec500's Avatar
Received 1,028 Likes on 612 Posts
Where did you buy your tire, many places offer roadhazard replacement. (TireRack includes it with all their tires)
Old 04-15-2021, 07:36 PM
darylbowden
darylbowden's Avatar
I would just replace the tire. Tires are the most important part of your car and that one is right on the shoulder. It might be fine but why be cheap when it comes to the only thing keeping you on the road?
Old 04-15-2021, 07:47 PM
shammerman
shammerman's Avatar
Not safe to repair as suggested above. This shows what can be plugged.
Old 04-15-2021, 07:48 PM
Tier1Terrier
Tier1Terrier's Avatar
Received 1,022 Likes on 511 Posts
I had nearly the exact same location with a nail in the tire. Much to my surprise, it did not actually go through the tread. I was ready to change the tire. I documented the whole thing in this video. But a patch would definitely not work that close to the sidewall.
Old 04-15-2021, 11:18 PM
Joec500
Joec500's Avatar
https://youtu.be/51J16386OLs
He said he was losing air though, so it prob went through.
Tier1Terrier (04-16-2021)
Old 04-16-2021, 12:20 AM
Jay2Lab
Jay2Lab's Avatar
Thanks for all the input everyone. I'm just going to replace the tire. It's definitely losing air since the sensor is detecting it and I sprayed some soapy water to confirm. I'll have to call around to the local tire shops since I'm worried about damage to the centerlocks. Worst-case scenario I'll just schedule the replacement with the dealer. This car is strictly used for spirited drives and autocross these days anyway.
Best,
J
Quick Reply: Patchable tire?
