Anyone use anti-seize on their wheel lugs?
That video was just setting off crazy heart palpitations. From the wrenches being so close to the body, to the crest tip not aligning with the valve. Nice how he fingered the camera while looking through the tire size...
You can fast forward to 4:50. If you have ever taken off a CL wheel, the paste is EVERYWHERE.
https://www.youtube.com/watch?v=WT1UqzQU3DA
What is the recommended torque for the bolts on NON center lock Porsche wheels?
Is 140 Nm correct?
Is 140 Nm correct?
I couldn't find any pdf on Rennlist about the exact detail of application of anti-seize on center lock hubs, but, as I understand it, you do put anti-seize on the hub threads and the conical (trapezoidal) portion of the center lock nut. You can put anti seize on the center lock threads because there is a locking pin, which prevents the nut from loosening. You do not want to use anti-seize on the standard lug nuts, as that will affect torque, and potentially allow them to loosen with use.
Porsche_nuts (04-15-2021)
new center lock nut, direct from factory
For anyone that has CL wheels, please refer to these Porsche documents. Read them and lube what they say to lube. Don’t lube what they say not too. Torque to spec with wheels off the ground.
https://www.dropbox.com/s/80j4xpkfc9...bible.pdf?dl=0
From my cursory review, the only divergence of opinion between the video above and this document is: 1. do not have wheels touching the ground during torque application, and 2. no need for anti-seize paste on the splines of the center lock nut (that comes in contact with the locking pin).
Both recommend anti-seize paste on the threads of the hub and central bolt. (The Porsche document calls these threads the trapezoidal threads, after their shape when viewing the thread at a perpendicular cross section.)
