991.1 and 991.2 xenon headlight compatibility
Old 03-27-2021, 01:12 AM
Juno317
2nd Gear
Juno317's Avatar
Question 991.1 and 991.2 xenon headlight compatibility
Hello!
I really want to install four-point headlights to my 991.1 carerra. I think the measures are exactly the same: 991.1 and 991.2 xenon headlights.
so I was wondering if I install 991.2 xenon headlights onto my 991.1, will they work without any ECU tune?
ncc1701D (07-07-2023)
Popular Reply
03-30-2021, 03:05 PM
JuanK20
JuanK20's Avatar
Default DIY
Ok so here is a quick DIY. There might be some gaps because I kept forgetting to stop to take pics. Also, i skipped the steps of removing the headlight because there are instructions for that all over the internet. DIY starts with headlights removed. You'll also need to remove the bumper. Once you install the 991.2 headlights, you will now need to remove the bumper anytime you want to remove the headlights.
Let me know if you guys have any questions.
Old 03-27-2021, 07:51 AM
JuanK20
JuanK20's Avatar
I put 991.2 headlights on my 991.1. The headlights mount and plug up fine. However to get the 4 point DRL to work, you’ll have to tap into the bumper DRL’s and wire it up to one of the empty pin/slots on the headlight plug. There is a slot the matches up to the pin on the headlight for the DRLs. I actually have to do them over sometime next week. I’ll try to take some pics of the process.
The following 3 users liked this post by JuanK20:
Honda (03-30-2021), Juno317 (03-27-2021), PJK3 (04-21-2021)
Old 03-27-2021, 01:09 PM
stout
stout's Avatar
Received 1,312 Likes on 610 Posts
Interesting thread. I don't know much about this, and would be curious to learn from anyone who does—but my "problem" is a bit different: I ordered PLDS in my 991.2, which comes with black upper housings under the lenses. Love the swiveling lights, but wish there had been a way to get the silver housings on a very dark car.
One of those things literally no one talks about, but I dig the dark housings on lighter cars, and the lighter housings on (most) dark cars. I wonder if there's a way to switch them…
Old 03-27-2021, 02:08 PM
Juno317
2nd Gear
Juno317's Avatar
OH! That sounds super awesome man!
It sounds like super minor job. So only thing extra is extend a drl wire and plug it to headlight?
Old 03-28-2021, 01:22 AM
Jack F
Jack F's Avatar
Taking off the bumper is not too bad and easier if you take off the front wheels and front wheel well liners. There are yt vids.
Old 03-28-2021, 01:56 AM
JK88
JK88's Avatar
you meant this white plug? i don't know where it should go. I looked up DRL but the plug looks completely different.
Old 03-28-2021, 08:09 AM
JuanK20
JuanK20's Avatar
No. That looks like the plug from the leveling module. There are 2 silver modules on the headlights. One is the HID ballast and one is for the leveling. Both of them swap over to the 991.2 headlight. See example below
For the DRL, The plug you have to tap into is the plug on your bumper lights and then you connect it to the plug that powers the headlight. (The connector from your car to the headlight)
I took the above pics from another thread. But I’ll take pics of what I actually did in the next few days.
The following 2 users liked this post by JuanK20:
Honda (03-30-2021), JK88 (03-28-2021)
Old 03-28-2021, 10:58 AM
Guards_Red_991
Guards_Red_991's Avatar
Subscribed...
Old 03-30-2021, 03:05 PM
JuanK20
JuanK20's Avatar
Default DIY
The following 12 users liked this post by JuanK20:
Cur (05-09-2023), edirtaynine (04-07-2021), Guards_Red_991 (03-30-2021), JK88 (03-31-2021), LandyAndy (03-30-2021), noahabel (07-27-2021), nolan12 (03-30-2021), polobai (03-31-2021), sbrooks64 (05-08-2023), spyderbret (04-22-2021), Stark7x (04-05-2021), Visual (03-30-2021) and 7 others liked this post. (Show less...)
Old 03-30-2021, 08:52 PM
JuanK20
JuanK20's Avatar
*** Updated the above post with a few more details.
Old 03-31-2021, 03:32 AM
JK88
JK88's Avatar
Thumbs up
WOW!! that looks fantastic man!!
Thank you so much!!!
The following 3 users liked this post by JK88:
JuanK20 (03-31-2021), ncc1701D (07-07-2023), zabuch (12-28-2022)
Old 04-07-2021, 08:21 PM
edirtaynine
edirtaynine's Avatar
man, if you were in socal, id offer to swap haha. i have a 991.1 with PDLS but without the black housing inside and want the darker housing.
Old 04-21-2021, 10:53 AM
flsupraguy
flsupraguy's Avatar
Received 1,483 Likes on 794 Posts
We need to make this thread a sticky.
Old 08-05-2021, 11:53 AM
epirok1
epirok1's Avatar
Default Headlight conversion worked!
Thanks so much for the write up! For me with base headlights (no PDLS) I only needed to tap the larger pin 10 from the yellow with the blue striped wire.
Added a switch in the extra 3rd hole on each side where the old 991.1 bracket access was. Can toggle the bumper DRL on and off. (I did straighten it out after I noticed from the picture that it was crooked!!!)
Fits the oval hole perfectly. In stock at Advance Auto Parts.
Old 08-05-2021, 01:28 PM
JuanK20
JuanK20's Avatar
Nice job! Glad it worked out.
Quick Reply: 991.1 and 991.2 xenon headlight compatibility
