Icarsoft V3.0 ? for oil reset
Old 03-19-2021, 06:19 PM
dannyss
dannyss's Avatar
Default Icarsoft V3.0 ? for oil reset
I'm assembling what I need for my first oil change on my 2019 Porsche C4S.
I've done a lot of oil changes on my other cars, but for the Porsche I need an oil reset tool.
I found that Icarsoft now has a V3.0 for Porsche, see Here: https://www.icarzone.us/Product/s-38...hecayenne.html
I can't find it an Amazon.
Can find a lot of references for V2.0 on the internet, but nothing about V3.0
Anybody get a V3.0 recently?
Old 03-19-2021, 06:29 PM
asellus
asellus's Avatar
Received 2,117 Likes on 1,320 Posts
I would be absolutely shocked if the 3.0 can't while the 2.0 can.
Then again, this is the same company that has a POR v1.0, POR v2.0, and POR II. I also don't see the v3.0 actually listed under the Porsche listings on their site, so I'm confused as to how you got to that page to begin with.
Old 03-19-2021, 06:41 PM
barncobob
barncobob's Avatar
doesnt it reset itself,just did mine 17CS and it had to get to 192 hot and then fiddled with it some more and it changed magically.
alainpp (03-19-2021)
Old 03-19-2021, 06:50 PM
mx-5
mx-5's Avatar
There seems to be some info about v3.0 online, but sparse.
I recently bought the iCarsoft CR v2.0 Multi-system unit so I can use on my other cars. While researching, I discovered some info about the v3.0 models but it looks like a drawback is v2.0 allows adding up to 10 car manufacturers while the new v3.0 is limited to 3. If you're only looking at specific make unit (ie. the POR unit), then of course this doesn't apply.
Old 03-19-2021, 08:34 PM
yoda888
yoda888's Avatar
What other cars can v2.0 support? Do you need to buy seperate modules, or does it support different cars out of the box?
I'm trying to find a scanner that will support my current (and future porsches) as well as other cars in the household. Currently the wife has a Q5. I'd like the flexibility of a single scan tool that can support multiple brands.
Old 03-19-2021, 08:41 PM
Rich_Jenkins
Rich_Jenkins's Avatar
I just wanted a basic "oil interval" reset tool, so I got this one, $99 on Amazon:
Amazon Amazon
From my post in Feb '20 in the oil change thread:
I started by verifying that my oil service interval needed to be reset. You turn on the ignition, then go to VEHICLE, then INFO, then SERVICE INTERVAL. I'm doing mine a little early to need.
Then I assembled my new Autel unit. It comes with a USB cable, and a data cable. I followed the instructions on the quick setup guide and attached it to my laptop. I then went to the Autel web site and registered the device, and activated my one free code set for "Porsche" (additional code sets are available from Autel). I then down loaded the code set and installed it in the reader. The instructions were fairly clear. This took about 15 minutes. After this, I was all set.
I then located the OBDII port. This is a bit hard to see, but it is in the driver side footwell, upper, tucked under the under side of the dash. The connector looks like this:
After inserting the connector firmly, you turn on the key and the reader starts to set itself up. You have to select the type of Porsche (991 for me):
Then you select the menus to initiate the oil reset (there are a few screens, this is a sample. Basically you follow the prompts)
The most fiddly part I found was that I discovered that for whatever reason, to "reset" the oil service for my car, I had to enter "todays" date in the data entry field.
You do this with a combination of moving the cursor around (it is hard to see the highlighted character, but it works) and hitting "enter" for that digit.
Anyway, once I entered today's date, I hit 'enter' and the reader did its thing.
The following 2 users liked this post by Rich_Jenkins:
huntflyer (02-17-2023), JuanK20 (03-19-2021)
Old 03-19-2021, 11:15 PM
mx-5
mx-5's Avatar
Other car makers listed in description
here here
Using iCarsoft's Windows app, and iCarsoft device connected to PC, you can select individual car makers you want, and the app will download them and install onto device. No cost. I added 4 onto mine.
Old 03-20-2021, 05:21 AM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,222 Likes on 739 Posts
Other car makers listed in description here
Do you have a link to ICarsoft for the downloads? Thx.
cyberay (03-20-2021)
Old 03-20-2021, 10:00 AM
dannyss
dannyss's Avatar
Their website is a mess. On the front page they show a V3.0 but when looking further they only show V2.0. The link in the original message is from a website called iCarzone.us. It seems to be a copy of the iCarsoft.us site. Is it legitimate?, can't tell.
I might call them on Monday. In any case Amazon.ca has V2.0 for cheaper than iCarsoft.
Old 03-20-2021, 11:21 AM
asellus
asellus's Avatar
My '17 did not reset itself, nor did anything through the MFD allow me to reset it.
Old 03-20-2021, 03:18 PM
mx-5
mx-5's Avatar
Check support&updates on their page for downloads and video.
Agreed, their website is a mess. Their site encryption also has issues. My home firewall decrypts and scans, but I need to disable decrypt and scan when visiting their site.
The following 2 users liked this post by mx-5:
hcamp19 (03-21-2021), Porsche_nuts (03-20-2021)
Old 03-29-2021, 01:17 AM
bb964
bb964's Avatar
For folks with ICarsoft POR V2.0 - there is a new update available - V21.01 and V11.45 (see below) https://www.icarsoft.us/Page/103.html
Not sure what are the changes as there are no release notes.
A newer version of the software update tool (3.19) is also available:
Also not clear what are the differences between V2.0 and V3.0, perhaps just the software that can be applied to V2.0??
V3.0 - https://www.icarsoft.us/Product/s-39...hecayenne.html
V2.0 - https://www.icarsoft.com/Product/s-3...ft_POR_V2.html
Porsche_nuts (03-29-2021)
Old 03-29-2021, 10:03 AM
dannyss
dannyss's Avatar
The page you linked to for V3.0 does not allow buying the unit, the "add to cart" button is disabled!I emailed Icarsoft a week ago and haven't received an answer yet on the availability and differences for the V3.0
Old 04-21-2021, 11:52 PM
bb964
bb964's Avatar
Now V3.0 is available on Amazon
Amazon Amazon
Based in the link below HERE’S WHAT HAS CHANGED:
The first change of note is that the iCarsoft V 3.0 is able to conduct actuation tests and auto VIN identity checks whereas the V2.0 OB2 scanner could not. Also there are a number of extra special service functions that relate to a range of systems that include:
  • Airbag crash data resets
  • Active damping control module tests
  • Adaptive speed control systems
  • Instrument cluster module tests
https://ljmcardiagnostics.co.uk/blog...canners-differ
Old 04-27-2021, 10:53 AM
Stark7x
Stark7x's Avatar
I need one of these tools for an oil change/reset... Wondering if 3.0 is worth buying over the 2.0. Difference is around 50$ it looks like. Not much, just don't want to end up getting one over the other and miss some options.
Quick Reply: Icarsoft V3.0 ? for oil reset
