Base 991.2 Spring Upgrade
Old Feb 20, 2021 | 12:11 PM
Irish996's Avatar
Irish996
Default Base 991.2 Spring Upgrade
Hi Folks, has anyone upgraded the stock springs only? Perhaps to S springs or something else?
Car is experiencing far too much body roll at higher speeds and need to stiffen things up without going coil over.
Already have DSC installed with GT3RS file loaded.
Not interested in dropping car too much from stock due to driveway and speed ramps.
Any advice appreciated.
Old Feb 20, 2021 | 12:41 PM
stout's Avatar
stout
Sounds like Sport PASM springs are what you need. Stiffer without much of a drop. Past that, it's time to move to Tractive dampers/custom springs or similar. Or a GT3.
I'd avoid any spring that's progressive—having learned the hard way after a number of people recommended them. PASM doesn't know what to do with rising rates, even with DSC. If I keep my Carrera, I will be redoing the springs—though I'll say the only place I find myself wanting more spring is the track…and this just isn't a track day car past 1~ day a year, if that.
Old Feb 20, 2021 | 12:43 PM
tgavem's Avatar
tgavem
Body roll is not only your springs but also sway bar. Maybe better to go to much stiffer sway bars but leave stock suspension, it will be cheaper.
Old Feb 20, 2021 | 12:49 PM
stout's Avatar
stout
^ Good call, and way cheaper. And easier to play with.
Worth talking to 2-3 good shops to get their input, from factory Sport PASM anti-roll bars to aftermarket stuff. There are some with direct experience on this forum, as well.
Old Feb 20, 2021 | 12:57 PM
Irish996's Avatar
Irish996
Cheers will investigate sport PASM springs 👍
Old Feb 20, 2021 | 01:00 PM
desmotesta's Avatar
desmotesta
sway bars and sway bat bushings is the first thingI would do, no question that would be a huge upgrade regarding body roll
Irish996's Avatar
Irish996
Good call! I don’t suppose you might know where would be a good source to pick these up?
Old Feb 20, 2021 | 02:23 PM
tgavem's Avatar
tgavem
Try Tarett engineering or call BGB Motorsport for recommendations
Old Feb 20, 2021 | 02:52 PM
Jack F's Avatar
Jack F
Have dealer quote you with OEM parts. Might not be horrible.
Old Feb 20, 2021 | 03:40 PM
mic_crispy's Avatar
mic_crispy
Why wouldn't you just go Bilstein B16?
Old Feb 21, 2021 | 09:39 AM
Irish996's Avatar
Irish996
In the shopping cart for a while now but strategy so far has been incremental improvements and realize there are other areas that will contribute to handling improvements without going coilovers straight away.
Old Feb 21, 2021 | 09:42 AM
Irish996's Avatar
Irish996
Old Feb 21, 2021 | 09:47 AM
Irish996's Avatar
Irish996
Originally Posted by garfunkle
I was going to call this out too. But first - what are you doing where it has too much body roll?
An OEM GT3 rear sway bar might be enough. Tarrett has some options too.
It's a rabbit trail though... end links, control arms, camber and camber plates. If you're going down this path because of too much body roll then you are probably a candidate for coilovers and an LSD too
At higher speeds the car can become very unsettled over undulations and bumps especially when already loaded up going through a bend etc.
I realize coils might be the practical solution but would like to address other parts such as sway bars first to see what a difference this makes.
Old Feb 21, 2021 | 10:20 AM
tgavem's Avatar
tgavem
Do you have MT or PDK, you can add LSD to the MT but not the PDK.
Old Feb 21, 2021 | 10:36 AM
GT3FZS's Avatar
GT3FZS
Trade the Base for a Carerra T,
SPASM, LSD (with 7 MT), DSC, add sway bars as necessary.
Or, what garfunkle said.
Good luck, keep us posted.
